Random number generator
Im using Rand Module to make a Random number generator, i assumed the seed option would allow for the input of a seed then a sequence of random number based of that seed, bbut it does not work how i expect. to clarify i want to input a value or string as a seed and based of that seed the random numbers should always have the same sequence.
I.E-- Seed = egg : result = 1,,5,33,7,,5,6,3,4...ect.. so egg should always produce this sequence.
Any idea how i can get this behaviour?
Thanks.
Thanks.
http://soundcloud.com/teslatronik Drop me a comment
TeslaTronik - Posts: 35
Re: Random number generator
Hmm, I'm not sure where your issues come from, but the rand prim does exactly that!
I don't have access to FS3 right now, but if you recreate the screenshot (I've set up 2 seeds, you can freely choose to always use the same, or alternate as you see fit), it should work.
Hello TeslaTronik,
Try these and see how they work for you!
Later then, BobF.....
- BobF
@ tulamide, Yes you are correct, it was the method of how i hooked it up which was wrong. thank you.
@Bobf thanks i will take a look at these ,, i love the idea of randomly generated parameters and sounds.. so the more methods the better.
Users browsing this forum: No registered users and 66 guests
