preset manager and preset string issue
Re: preset manager and preset string issue
Postby Jay » Mon Apr 08, 2013 3:17 pm
hmmm it is a pain this one tester eh! never mind, we will get there in the end :)
will have a further look at it this evening m8!
Jay
Postby Jay » Tue Apr 09, 2013 5:12 pm
Hi tester try this one! it seems to work ok here!
preset-manager-problem fix e.rar
(24.35 KiB) Downloaded 1150 times
Jay
Postby tester » Wed Apr 10, 2013 12:42 pm
Hmm... Still the same problem.
On an example:
1) after shape is loaded manually via "s" box in "osc 01",
2) then switching between programs on preset manager (arrows under "name") shows
3) that this shape is being loaded to all programs.
This should not happen, because programs are separate.
p.s.: in "fix e" zip is a project named "fix d" - did you uploaded correct version?
tester
Postby VPDannyMan » Fri Apr 19, 2013 5:58 am
Not sure if this info is valid or not, but at one time the preset string param did not throw triggers properly... On the before or after, or sometimes when the text changed..
VPDannyMan
Postby Nubeat7 » Fri Apr 19, 2013 11:22 am
oh yes, i recognised this few days ago too in my fx selector viewtopic.php?f=2&t=1335&start=10 .. there i had to use the after load triggers from the presetmanager instead of the preset string to get the selector updated properly after presetchange!
Postby tester » Fri Apr 19, 2013 5:08 pm
Generally this issue killed a good idea in my project, so I hope in the future they rebuild this "preset string" primitive, to allow turn on/off it from preset manager, like the "preset parameter".
tester
Postby Nubeat7 » Fri Apr 19, 2013 6:58 pm
i mde the test now, and yes its defenitly true the presetstring dont send an after change trigger ! maybe it should be reported at the support..
i donot have the time to watch your schematic tester but if this is the problem in your schematic maybe you can úse the trigger from the presetmanager for your needs? good luck
Schematic1.fsm
no after change trigger at string preset
(7.05 KiB) Downloaded 994 times
Postby Jay » Fri Apr 19, 2013 9:33 pm
great detective work guys! as you can see i was trying to get this working for tester and it has had me lost, i knew it was a trigger issue but could not find it! you have no idea the amount of times i have torn it down and rebuilt it lol
Jay
Postby tester » Sat Apr 20, 2013 5:15 pm
Puff... I think I give up it for a while. Weather changed from snowy to sunny spring; it's time to recharge batteries.
tester
Postby VPDannyMan » Sun Apr 21, 2013 5:10 am
Nubeat7 wrote:i mde the test now, and yes its defenitly true the presetstring dont send an after change trigger ! maybe it should be reported at the support..
I did report this already over a year ago. Instead of waiting I just reworked my project so that it used something else for triggering. There are other things that are far more important to see get worked on. This error HAS a work around, other things do not, so I never stressed the point of fixing this error again.
VPDannyMan
