Http Post local - WebMatrix 3
Postby CoreStylerz » Sat Jun 15, 2013 1:34 pm
Hi all,
I want to use HTTP Post module for sending data to IIS server using WebMatrix 3 IDE.
Jus't it doesn't act.
I specified the local url: http://localhost:63089/ and page correctly but seems to not work?
Is possible then to use it locally?
Thanks 8-) :oops:
PM me if you are interested.
CoreStylerz
Re: Http Post local - WebMatrix 3
Postby MyCo » Sat Jun 15, 2013 2:47 pm
I've tried it. You can use it locally with "localhost" or "127.0.0.1", both work. Unfortunately only Port 80 is supported. So no matter what you enter into "URL" input, it tries to use that String as Domain and connect to Port 80 of it.
MyCo
Postby chackl » Sun Jun 16, 2013 8:20 pm
Hello!
Try this:
URL-String:
localhost:63089
Page-String:
"" (empty - leave it blank)
Nothing more and it may work.
HTTP Post is able to comunicate with other ports than 80 ;)
it is like that:
Domain:port
Regards
chackl
