overload detector (mono to mono4)
How to convert this overload detector (peak detection) into something that accepts mono4 input (first 2 channels), and outputs two mono streams? I noticed that I always have many of them running, so I thought that I could save some CPU by converting them into mono4 singularities. Original design from Trogz Tools.
- detector.fsm
- (1007 Bytes) Downloaded 842 times
Re: overload detector (mono to mono4)
Just use unpack
- packed-detector.fsm
- (962 Bytes) Downloaded 889 times
MyCo - Posts: 718
Thanks.
Funny thing. I'm watching at these little asm things, and - on one hand I start to see how it works. But when it comes to some action - I'm getting dumb again, as if I was switching into "uninhabited" part of my brain.
//edit:
Ah, I see what you mean. I thought about putting this unpack part (2 channels) into the ASM code.
//edit:
You can do the unpack in the code, but there is no benefit in doing this.
MyCo - Posts: 718
That's what I wanted to know, thanks.
Users browsing this forum: No registered users and 70 guests
