how to get a fraction in blue
How to get (simplest way) a factional part in blue?
Like 4.543 -> 0.543
rndint(x) works differently than green int philosophy.
Like 4.543 -> 0.543
splitter.fsm- (1.39 KiB) Downloaded 952 times
Re: how to get a fraction in blue
out = in-rndint(in);
- strangeChild
Nope. Check the numbers with fraction above #.5, like 3.8
Code int rounds up or down. Green integer splits the integer and fractional part.
Yeah... posted without checking (or thinking!)... Sorry.
- strangeChild
out = in - rndint(in-0.5);
But only with positive values
For negative and positive values this looks like it works:
(the assembly people can give you a proper solution)
EDIT - final - DOESN'T WORK WITH FLOATS THAT ARE ALREADY INTEGERS... I'll shut up now.
streamin in;
streamout out;
float adj;
adj = 0.5 - (1 & (in<0));
out = in - rndint(in-adj);
- strangeChild
Need for both - positive and negative values.
Was editing last post when you replied... but as I said the assembly guys will give you something much better but this does seem to work.
- strangeChild
Yeah, just came to similar thing, but I was wondering - if there is a simpler, "one operation" way.
splitter1.fsm- (1.85 KiB) Downloaded 925 times
This doesn't look simpler, but actually it's a lot faster.
Stream fraction (MyCo).fsm- (1.85 KiB) Downloaded 966 times
MyCo - Posts: 718
for something that looks simple...
I missed that there's a modulus divide.
out = in%1;
- strangeChild
