Requests for Ruby Edit
Postby chackl » Thu Oct 10, 2013 2:46 pm
Hello!
I've spent now a lot of time with lerning ruby with FlowStone - And i realy like it ;)
I also coded with som other languages - mostly VB6, VBA and C++ and the all come up this realy good solutions within the editor of the code.
This is no request to copy those solutions but i think they will make programming in Ruby more comfortable.
Popup list is i have written a "." (Dot) after any object. In VBA (Access) it looks like that if i'm editing a TextBox:
I'm using that realy often - And also i look often through the list to get a feeling, what i'm able to do this this object ;)
Next one i'm usig verry verry often: Single-Step
For users that do not know: Every time i press F8 the next line will be executed. So i'm seeing whitch way the procedure takes. The Line that is executed next is marked like that: (AutoCAD VBA)
Next one i realy like here is that if i'm moving the curser to any variable with a String or any value a kind of curser-line appears and tells me the variable tat is stored to it: (AutoCAD VBA)
Also a "Stop at line" would be verry cool ;)
Next would be a Line-Number - and If there is an error - the controll will tell the class and line where an error was done.
Would this be possible to see some of those things in future?
Best Regards,
C.Hackl
chackl
Re: Requests for Ruby Edit
Postby CoreStylerz » Thu Oct 10, 2013 3:58 pm
Webmatrix also cool:
PM me if you are interested.
CoreStylerz
Postby Nubeat7 » Thu Oct 10, 2013 11:04 pm
you tried aptana(free) or rubymine (not free) also netbeans should do a good job?
after a quick search i think these are the most common ide`s for using ruby...
just writing the code inside there with all the ide features and copy / paste it after would be an easy and comfortable way to get features like this
but yes, some more features in the ruby module would be helpful, i want line numbers and better error infos too! :)
Postby trogluddite » Thu Oct 10, 2013 11:18 pm
Not just Ruby - even in SM, I always wanted some more useful de-bugging tools.
For example - a value viewer window, so that you can tag connectors or links anywhere in the schematic and see their values changing in real time, even when those parts of the schematic are not visible in the editing window.
But, yes line numbers and backtraces! It's not hard to do either. For example, I often end my "event" method like this...
def event(i,v,t)
  # CODE #
rescue => error
  watch "Error message",error.message
  watch "Error trace",error.backtrace
  raise error  # Make sure that the error still stops the interpreter
...the 'backtrace' line shows a list of all the nested method calls leading up to the error (so long as the call started from an event, of course) - including a method name and line number for each step of the way (which I then have to go into NotePad++ to find, because that has the line numbers!).
Ruby's built in exception handling is exceptionally ( :roll: ) flexible, so it wouldn't be difficult to hook into it.
Postby gul123 » Mon Oct 14, 2013 1:37 pm
:lol: Not just Ruby - even in SM, I always wanted some more useful de-bugging tools.
gul123
Postby tester » Mon Oct 14, 2013 1:55 pm
...and green primitive with (e) letter (like F, I, S for float/int/string), for simple expressions, like 1/7 or 2^0.5 or in^0.5 - things like that.
tester
Postby trogluddite » Mon Oct 14, 2013 7:45 pm
gul123 wrote::lol: Not just Ruby - even in SM, I always...
Always nice to hear that folks have found my optimised echo/delay modules so useful - I'm amazed that they have ported so well to BBcode! :shock: :lol:
