Page 3 of 3
Re: Triggering switches with Midi notes.
Posted: Sun Sep 30, 2018 5:57 pm
by lalalandsynth
OH, really, thats it , and this works as polyphonic?
Posted: Sun Sep 30, 2018 6:52 pm
by lalalandsynth
Yep, this works, except it went back to a mono signal, checking if i did something wrong.
I changed the one you made to work with 12 stereo channels or 24 mono ,so each note was triggering a stereo channel.
With the ADSR that is lost and I am back to mono.
I can upload my schematic if you can open an alpha ?
Donated
Posted: Sun Sep 30, 2018 7:02 pm
by lalalandsynth
With this configuration through the adsr I get mono.
Ones below are from before with no ADSR and they work as stereo.
Must say , I am a bit frustrated that my skill level is so low that I cannot figure this out .
I could obviously just have 2 Adsr“s with one set of controls but that seems like a workaround
- Mono.jpg (155.96 KiB) Viewed 21551 times
Posted: Sun Sep 30, 2018 7:10 pm
by lalalandsynth
Stereo configuration
- config.jpg (191.23 KiB) Viewed 21551 times
Posted: Sun Sep 30, 2018 9:36 pm
by martinvicanek
You can go stereo like this:
- StereoRoting.png (16.82 KiB) Viewed 21548 times
Simply pack and unpack the L/R channels into a Mono4 stream - everything else remains unchanged.
There is a lot to optimize but that's for later. Thanks for the donation!
Posted: Sun Sep 30, 2018 9:40 pm
by lalalandsynth
Thanks again , so simple ...unless you dont know how
Posted: Sun Sep 30, 2018 11:36 pm
by lalalandsynth
Hmm, everything sound distorted now.
Having a look, sounds fine in FS (EDIT: IT IS DISTORTED IN FS AS WELL: ,distorted in Reaper, previous version without ADSR sounded fine in Reaper
Not sure what happened , it sounded fine in mono.
No reason for it to be the Pack/unpack , already using that in the volume knob and Clip.
Its weird I can pull the gain from my test osc to -70 , still has no effect on lowering the sound.
Same thing in reaper , lowering the input file had almost no effect , almost like everything is normalized/maximized and distorted ?
Ok, so bypassing the adsr and going straight from pack to unpack solves the distortion , distortion happens at the adsr ,
Posted: Mon Oct 01, 2018 12:31 am
by lalalandsynth
Replaced all ADSRs with the same one from the toolbox and it now works !?
Who knows , might be an alpha issue ?
Posted: Mon Oct 01, 2018 12:46 am
by lalalandsynth
Lol, still some issues , Looks like if the release gets stuck at almost full levels.
I just move the knob slightly from zero and it plays full release, and not always .
Something is still wrong.
EDIT: The envelope gets stuck on "Full release" in FS and reaper ,when the decay is on full and the release is lifted slightly.
Taking a break
Posted: Mon Oct 01, 2018 5:42 pm
by lalalandsynth
Sent you a PM Martin.
