Triggering switches with Midi notes.
- lalalandsynth
Can I somehow trigger switches and hold for the duration of a midi Note ?
- lalalandsynth
Re: Triggering switches with Midi notes.
Basically I want an octave of notes to each trigger a separate ADSR/VCA.
Working on this but have not done much midi stuff in FS so far.
maybe you could use an equals to the note to gate the adsr,
and not use midi in an unusual way.
This would be done in poly, with the output from the midi to poly
The adsr will have to have the gate option checked in properties
hope helps!
hope helps!
- lalalandsynth
That is exactly what I did but it did not work properly , admittedly i am quite rusty in FS.
Midi in to -equal to note -to gate , however there were problems when using more then one note.
It seems the first note triggered both adsrs even though the second one had a different equal to.
Obviously doing something stupid here .
Here is an schem, 64 alpha though.
try this->
hope helps
the envelope in your schem needs to be fixed, there seems to be some problems with it
- lalalandsynth
Thanks , this works perfectly , I will have a look at the envelopes , I need an adsr with the option of gate only so I will look through my library.
- lalalandsynth
Would you mind explaining why the pitch from the MIDI to poly goes to the combiner ?
I would need this as an effect so I need to change to Mono and not sure how to go about that and maintain this as working. After changing the VCAs to mono and exporting as VST , it semi works but not properly , something wrong with how it reacts polyphonically , which is reasonable seeing as I messed with that part.
Also it does not really react to 32nd part notes , the adsr or the VCA is not reponsive enough or something.
EDIT: After a bit of testing , yes does not work in a polyphonic manner , having said that the idea is turning out nice, just need to figure out how to make the adsr/vca faster and make it poly.
64 bit alpha
[attachment=0]Midi Trigger mixer_edit_5_5.fsm/attachment]
64 bit alpha
- Midi Trigger mixer_edit_5_5.fsm
- (169.61 KiB) Downloaded 985 times
- lalalandsynth
Hmm, trying various things , Is it not possible to have multiples adsrs that work in a poly fashion ?
That does not really make sense.
I dunno mate, I"ll stay tuned.
Here is the mono one working I think-> edit->Please stay in touch and we'll get this working
- lalalandsynth
Yes, this one "works" as in that it passes sound and the notes each trigger correctly but i cannot play two notes at a time , also if one note extends over the first one there is a strange interaction between the envelopes. I want them to be completely independent , not sure why they do this , if its a midi thing or related to what envelopes i am using?
Weird thing is that the release can run over a previous note and not get choked, just as long as the notes dont play at the same time ...it seems.
Also, they cant seem to handle anything faster/shorter then 32 nd notes at a 140 bpm.
Doing some testing.
Doing some testing.
