FlowStone User Defined Modules Manager
Posted: Tue Mar 29, 2022 3:36 pm
Download Link:
https://www.inventfx.com/_ifxfstone/flwstmgr.zip
Filename: flwstmgr.zip
Written as a powerful batch file script. Extensively tested for errors and compiled into executable with Licensed Commercial Version Advanced Batch To Executable Converter Software Designed by By B. Dargo.
A versatile management command line style console for the custom user modules folder.
This folder is located in a 'hidden' directory "AppData" on Windows Computers and the full path is:
C:\Users\<Username>\AppData\Roaming\Flowstone\Modules
Optional Sub-folders:
User Defined (Add a user defined folder name to the toolbox tag list on far left of FlowStone program to initially utilize the FlowStone User Defined Modules Manager.)
Deleted Modules (automatically created by FlowStone when a toolbox file is deleted.)
The Flowstone User Defined Modules Manager is self-explanatory and easy to use with the following features:
Initial creation of the main FlowStone User Defined Modules folder if non-existent.
Instant backup of the main folder as FlowStone_bak containing all existing files and modules.
Each new backup automatically replaces older files with newer ones and adds any new ones automatically.
Optional add files only backup will overwrite existing files and add any new ones without removing exclusive files in FlowStone_bak folder.
Instant restore of the entire FlowStone folder from the FlowStone_bak folder.
Each new restore automatically replaces newer files with older ones and removes any new ones automatically.
Optional copy files only will restore previous files without removing any newer files in FlowStone folder.
Also manages the Deleted Modules folder.
Access and use the Windows %SystemRoot% Recycle Bin folder with option to view and/or clean it immediately. It opens immediately on the Desktop along with the other FlowStone folders for interactive use.
All options are simply YES or NO with absolutely no guesswork needed. Very simple to use even for beginners and fast operation for the well versed 'Flowstoners' in our midst.
Download Link:
