FlowStone User Defined Modules Manager
- pwesynthmaker
Download Link:
https://www.inventfx.com/_ifxfstone/flwstmgr.zip
Filename: flwstmgr.zip
Written as a powerful batch file script. Extensively tested for errors and compiled into executable with Licensed Commercial Version Advanced Batch To Executable Converter Software Designed by By B. Dargo.
A versatile management command line style console for the custom user modules folder.
This folder is located in a 'hidden' directory "AppData" on Windows Computers and the full path is:
C:\Users\<Username>\AppData\Roaming\Flowstone\Modules
Optional Sub-folders:
User Defined (Add a user defined folder name to the toolbox tag list on far left of FlowStone program to initially utilize the FlowStone User Defined Modules Manager.)
Deleted Modules (automatically created by FlowStone when a toolbox file is deleted.)
The Flowstone User Defined Modules Manager is self-explanatory and easy to use with the following features:
Initial creation of the main FlowStone User Defined Modules folder if non-existent.
Instant backup of the main folder as FlowStone_bak containing all existing files and modules.
Each new backup automatically replaces older files with newer ones and adds any new ones automatically.
Optional add files only backup will overwrite existing files and add any new ones without removing exclusive files in FlowStone_bak folder.
Instant restore of the entire FlowStone folder from the FlowStone_bak folder.
Each new restore automatically replaces newer files with older ones and removes any new ones automatically.
Optional copy files only will restore previous files without removing any newer files in FlowStone folder.
Also manages the Deleted Modules folder.
Access and use the Windows %SystemRoot% Recycle Bin folder with option to view and/or clean it immediately. It opens immediately on the Desktop along with the other FlowStone folders for interactive use.
All options are simply YES or NO with absolutely no guesswork needed. Very simple to use even for beginners and fast operation for the well versed 'Flowstoners' in our midst.
Download Link:
- flwstmgr.jpg (29.66 KiB) Viewed 11326 times
Last edited by pwesynthmaker on Fri Jun 26, 2026 3:39 pm, edited 16 times in total.
Inventor eFX Technology
- pwesynthmaker
Re: FlowStone User Defined Modules Manager
For those whom have the savvy and to comply with forum guidelines I am providing my original batch script code..
FlowStone User Defined Modules Manager Batch to Exectuable Script
:: RUN AS ADMINISTRATOR ::
@echo off
if _%1_==_payload_ goto :payload
:getadmin
echo %~nx0: elevating self
set vbs=%temp%\getadmin.vbs
echo Set UAC = CreateObject^("Shell.Application"^) >> "%vbs%"
echo UAC.ShellExecute "%~s0", "payload %~sdp0 %*", "", "runas", 1 >> "%vbs%
"%temp%\getadmin.vbs"
del "%temp%\getadmin.vbs"
goto :eof
:payload
color f0
echo.
echo.
echo FLOWSTONE USER DEFINED MODULES MANAGER
echo.
echo AT ANY TIME DURING THE FOLLOWING PROCEDURES ...
echo TO EXIT WITHOUT CHANGE ...
echo ONLY PRESS "X" CHECK BOX IN UPPER RIGHT OF THIS WINDOW!
echo.
echo.
pause
if exist %UserProfile%\AppData\Roaming\FlowStone (
goto :flwstfldr
) else goto :chkflwstfldrbak
:flwstfldr
color f1
echo.
echo.
echo To OPEN AppData\Roaming FlowStone Folder ...
echo Type "Y" For YES Then Press "ENTER".
echo.
echo Or Press Any Key For Backup Folder Option(s) ...
set "reply=n"
set /p "reply= %USERREG%"
if /i not "%reply%" == "y" goto :mngflwstfldrbak
start %UserProfile%\AppData\Roaming\FlowStone
echo.
echo.
pause
goto :rcyclbin
:mngflwstfldrbak
if exist %UserProfile%\AppData\Roaming\FlowStone_bak (
goto :add2flwstfldrbak
) else goto :mkflwstfldrbak
:add2flwstfldrbak
color f2
echo.
echo.
echo To ONLY ADD NEW/CHANGED FILES To FlowStone_bak Backup Folder ...
echo.
echo Or Press Any Key For BACKUP COMPLETE Option ...
set "reply=n"
if /i not "%reply%" == "y" goto :mkflwstfldrbakup
xcopy "%UserProfile%\AppData\Roaming\FlowStone" "%Userprofile%\AppData\Roaming\FlowStone_bak" /i /r /h /s /e /k /o /x /y
echo.
echo.
pause
echo.
echo.
echo Open The FlowStone-bak Folder To Confirm Added Files ...
echo.
echo Or Press Any Key To Continue ...
set "reply=n"
if /i not "%reply%" == "y" goto :delfldr
start %UserProfile%\AppData\Roaming\FlowStone_bak
echo.
echo.
pause
goto :rcyclbin
:mkflwstfldrbak
color 2f
echo.
echo.
echo To BACKUP COMPLETE AppData\Roaming FlowStone Folder
echo To FlowStone_bak Folder ...
echo.
echo Or Press Any Key To EXIT.
set "reply=n"
if /i not "%reply%" == "y" goto :exit /b
goto :bkupflwstfldr
:mkflwstfldrbakup
color 2f
echo.
echo.
echo.
echo Or Press Any Key For Restore FlowStone Folder Option ...
set "reply=n"
if /i not "%reply%" == "y" goto :flwstfldrbak
echo.
echo.
echo ... OR ... TO CONFIRM ACTION
echo BACKUP COMPLETE AppData Roaming FlowStone Folder ...
echo.
echo Continue As Instructed Below.
echo.
echo.
pause
goto :rmflwstfldrbak
) else goto bkupflwstfldr
:rmflwstfldrbak
rmdir /q /s %UserProfile%\AppData\Roaming\FlowStone_bak
:bkupflwstfldr
echo.
echo.
pause
echo.
echo.
echo Open The FlowStone-bak Folder To Confirm Backup ...
echo.
set "reply=n"
echo.
echo.
pause
goto :rcyclbin
:chkflwstfldrbak
goto :flwstfldrchk
) else goto :mkusrfldr
:flwstfldrchk
goto :flwstfldrbak
) else goto :rstrflwstfldr
:flwstfldrbak
color fa
echo.
echo.
echo To ONLY COPY FILES From FlowStone_bak Folder
echo To AppData\Roaming FlowStone Folder ...
echo.
echo Or Press Any Key To Continue For REPLACE COMPLETE Option ...
set "reply=n"
if /i not "%reply%" == "y" goto :rplcflwstfldr
xcopy "%UserProfile%\AppData\Roaming\FlowStone_bak" "%UserProfile%\AppData\Roaming\FlowStone" /i /r /h /s /e /k /o /x /y
echo.
echo.
echo Open The FlowStone Folder To Confirm Copied FIles ...
echo.
set "reply=n"
echo.
echo.
pause
goto :rcyclbin
:rstrflwstfldr
color af
echo.
echo.
echo To RESTORE COMPLETE AppData\Roaming FlowStone Folder
echo From FlowStone_bak Folder ...
echo.
set "reply=n"
echo.
echo.
echo Open The FlowStone Folder To Confirm Restore ...
echo.
set "reply=n"
echo.
echo.
pause
goto :rcyclbin
:rplcflwstfldr
color af
echo.
echo.
echo To REPLACE COMPLETE AppData\Roaming FlowStone Folder
echo.
set "reply=n"
echo.
echo.
echo REPLACE COMPLETE AppData Roaming FlowStone Folder ...
echo.
echo.
echo.
pause
rndur /q /s %UserProfile%\AppData\Roaming\FlowStone_bak
echo.
echo.
echo Open The FlowStone Folder To Confirm Replace ...
echo.
set "reply=n"
echo.
echo.
pause
goto :rcyclbin
:delfldr
if exist %UserProfile%\AppData\Roaming\FlowStone\Modules\"Deleted Modules" (
goto :viewdelfldr
) else goto :exit /b
:viewdelfldr
color f5
echo.
echo.
echo To Open The FlowStone Deleted Modules Folder ...
echo.
echo Or Press Any Key For CLEAR FlowStone Deleted Modules Option ...
set "reply=n"
if /i not "%reply%" == "y" goto :clrdelfldr
%SystemRoot%\Explorer.exe %UserProfile%\AppData\Roaming\FlowStone\Modules\Deleted Modules
echo.
echo.
pause
goto :rcyclbin
goto :clrdelfldr
:clrdelfldr
color df
echo.
echo.
echo To CLEAR FlowStone Deleted Modules Folder ...
echo.
echo Or Press Any Key For REMOVE Deleted Mudules Folder Option ...
set "reply=n"
set /p "reply=%USERREG%"
if /i not "%reply%" == "y" goto :rmdelfldr
rmdir /q /s %UserProfile%\AppData\Roaming\FlowStone\Modules\"Deleted Modules"
mkdir %UserProfile%\AppData\Roaming\FlowStone\Modules\"Deleted Modules"
:rmdelfldr
color 5f
echo.
echo.
echo To REMOVE FlowStone Deleted Modules Folder ...
echo.
set "reply=n"
goto :exit /b
:mkusrfldr
color e4
echo.
echo.
echo CAUTION!
echo.
echo Request Required To Create Initial FlowStone Modules Folder ...
echo.
echo To Create FlowStone Modules Folder ...
echo.
set "reply=n"
echo.
echo.
pause
goto :flwstfldr
:rcyclbin
color f4
echo.
echo.
echo OPEN Recycle Bin Folder ...
echo.
echo Or Press Any Key To Exit ...
set "reply=n"
start shell:recyclebinfolder
echo.
echo.
pause
color 4f
echo.
echo.
echo CLEAR Recycle Bin Folder ...
echo.
set "reply=n"
rd /s /q C:\$RECYCLE.BIN
pause
:eof
:exit/b
exit
@echo off
:getadmin
goto :eof
:payload
color f0
echo.
echo.
echo.
echo.
echo.
pause
goto :flwstfldr
:flwstfldr
color f1
echo.
echo.
echo.
set "reply=n"
echo.
echo.
pause
goto :rcyclbin
:mngflwstfldrbak
:add2flwstfldrbak
color f2
echo.
echo.
echo.
set "reply=n"
echo.
echo.
pause
echo.
echo.
echo.
set "reply=n"
echo.
echo.
pause
goto :rcyclbin
:mkflwstfldrbak
color 2f
echo.
echo.
echo.
set "reply=n"
goto :bkupflwstfldr
:mkflwstfldrbakup
color 2f
echo.
echo.
echo.
set "reply=n"
echo.
echo.
echo.
echo.
echo.
pause
:rmflwstfldrbak
:bkupflwstfldr
echo.
echo.
pause
echo.
echo.
echo.
set "reply=n"
echo.
echo.
pause
goto :rcyclbin
:chkflwstfldrbak
goto :flwstfldrchk
:flwstfldrchk
goto :flwstfldrbak
:flwstfldrbak
color fa
echo.
echo.
echo.
set "reply=n"
echo.
echo.
echo.
set "reply=n"
echo.
echo.
pause
goto :rcyclbin
:rstrflwstfldr
color af
echo.
echo.
echo.
set "reply=n"
echo.
echo.
echo.
set "reply=n"
echo.
echo.
pause
goto :rcyclbin
:rplcflwstfldr
color af
echo.
echo.
echo.
set "reply=n"
echo.
echo.
echo.
echo.
echo.
pause
echo.
echo.
echo.
set "reply=n"
echo.
echo.
pause
goto :rcyclbin
:delfldr
goto :viewdelfldr
:viewdelfldr
color f5
echo.
echo.
echo.
set "reply=n"
echo.
echo.
pause
goto :rcyclbin
goto :clrdelfldr
:clrdelfldr
color df
echo.
echo.
echo.
set "reply=n"
:rmdelfldr
color 5f
echo.
echo.
echo.
set "reply=n"
goto :exit /b
:mkusrfldr
color e4
echo.
echo.
echo CAUTION!
echo.
echo.
echo.
set "reply=n"
echo.
echo.
pause
goto :flwstfldr
:rcyclbin
color f4
echo.
echo.
echo.
set "reply=n"
echo.
echo.
pause
color 4f
echo.
echo.
echo.
set "reply=n"
pause
:eof
:exit/b
exit
