Server in .exe issue *FIXED*
Hi, i can not make the Network Server module work when exported to .exe, it just won't start and seems not even try to connect. It do work inside FS, also Network Client works in .exe but not the server or am i missing something?
- Morph
Re: Server in .exe issue
hello,
same problem here.
Sometimes It doesn't start inside Flowstone too(try to push start several times and it will fail to start).
S.
same problem here.
S.
- sal
I have it working inside an EXE?
- DSP
DSP wrote:I have it working inside an EXE?
Is this test .exe working for you, DSP? TEST Server
Inside:
- server.png (21.45 KiB) Viewed 28929 times
- Morph
it doesn't work here.
There is something to be fixed on the server module.
S.
S.
- sal
Morph wrote:Hi, i can not make the Network Server module work when exported to .exe, it just won't start and seems not even try to connect. It do work inside FS, also Network Client works in .exe but not the server or am i missing something?
Did you exit FlowStone before starting the executable?
Because, if not, the server inside FS is still using the selected port numbers, thus rendering those ports unusable for anyone else, including FS executables.
Tom
- TomC
TomC wrote:Did you exit FlowStone before starting the executable?
Yes, had tried on other computers too, with no FS installed. No network activity.
Try my test .EXE. Is it working for you?
- Morph
Users browsing this forum: No registered users and 52 guests
