Server in .exe issue *FIXED*
Postby Morph » Sat Jan 15, 2011 4:37 pm
Hi, i can not make the Network Server module work when exported to .exe, it just won't start and seems not even try to connect. It do work inside FS, also Network Client works in .exe but not the server or am i missing something?
Morph
Re: Server in .exe issue
Postby sal » Sun Jan 16, 2011 11:31 pm
hello,
same problem here.
Sometimes It doesn't start inside Flowstone too(try to push start several times and it will fail to start).
S.
sal
Postby DSP » Sun Jan 16, 2011 11:48 pm
I have it working inside an EXE?
DSP
Postby Morph » Mon Jan 17, 2011 12:39 pm
DSP wrote:I have it working inside an EXE?
Is this test .exe working for you, DSP? TEST Server
Inside:
Morph
Postby sal » Mon Jan 17, 2011 4:19 pm
it doesn't work here.
There is something to be fixed on the server module.
S.
sal
Postby TomC » Wed Jan 19, 2011 3:10 pm
Morph wrote:Hi, i can not make the Network Server module work when exported to .exe, it just won't start and seems not even try to connect. It do work inside FS, also Network Client works in .exe but not the server or am i missing something?
Did you exit FlowStone before starting the executable?
Because, if not, the server inside FS is still using the selected port numbers, thus rendering those ports unusable for anyone else, including FS executables.
Tom
TomC
Postby Morph » Wed Jan 19, 2011 3:36 pm
TomC wrote:Did you exit FlowStone before starting the executable?
Yes, had tried on other computers too, with no FS installed. No network activity.
Try my test .EXE. Is it working for you?
Morph
