Multiplex & audio routing.
Postby lalalandsynth » Wed Mar 06, 2019 6:39 pm
I know the quirks of the multiplex in terms of routing values but I cannot remember if its supposed to work properly for routing audio signals , it is not working properly for me at least.
What to do when you need to route one Audio source to mutiple places and cannot use the Selector ?
Never really understood why there is not a selector with one input and multiple outputs .
I think there might be something else wrong here.
I have two signals going into a selector and it plays NR1 even though I switch in NR2 ?
ok, restarted FS , and it seems to work now , super weird !
lalalandsynth
Re: Multiplex & audio routing.
Postby Nubeat7 » Fri Mar 08, 2019 7:41 pm
sure you can use the multiplexer for audiorouting.
using the multiplexer forces a recompile everytime you change the target, this can result in audiocrackles.
to avoid this you can write it in dsp code like this.
multiplexer.fsm
(1.16 KiB) Downloaded 880 times
Postby RJHollins » Sat Mar 09, 2019 12:49 am
Nubeat7 wrote:sure you can use the multiplexer for audiorouting.
Very cool NuBeat ...
I know DSP less than RUBY ... saying that ... how to expand this Multiplex to handle Stereo pairs ?
Postby Nubeat7 » Sat Mar 09, 2019 7:55 pm
just use packed mono4 ins and outs...
Postby RJHollins » Sat Mar 09, 2019 11:58 pm
Nubeat7 wrote:just use packed mono4 ins and outs...
Thank-you Sir ... I'll give that a try.
Postby RJHollins » Sun Mar 10, 2019 8:03 pm
OK ... got it working with the PACK in/outs.
Thanks again NuBeat 8-)
Postby lalalandsynth » Mon Mar 11, 2019 7:03 pm
Thanks , this works great !
lalalandsynth
