Flowstone wishlist
Re: Flowstone wishlist
Postby MyCo » Tue Apr 11, 2017 8:11 pm
I'm not sure about that, I guess you could make it work somehow but it would be very limited. Like you said, just pointer+length, as converting the memory to ruby and back would hit the same bottleneck
MyCo
Postby BobF » Thu Apr 20, 2017 2:03 pm
Hello all,
How about harddrive, sd card, and thumb drive access!
Later then, BobF.....
BobF
Postby Spogg » Thu Apr 20, 2017 4:02 pm
BobF wrote:How about harddrive, sd card, and thumb drive access!
What had you got in mind Bob? You can already load and save stuff to/from any drive on the PC.
Postby BobF » Thu Apr 20, 2017 5:24 pm
Hello Spogg,
Do you have an example? Funny as long as I have been using Flowstone there seems to still be things I have missed.
But I see that as a good thing, always more to learn.
Thanks, BobF.....
BobF
Postby tulamide » Fri Apr 21, 2017 2:56 pm
Hey Bob,
saving is done through the various save-Prims (there are prims for saving bitmaps, wavefiles, text, etc.). Access to a location on a storing device is done via the File Dialog Prim. And loading again is done via prims.
Postby BobF » Sat Apr 22, 2017 7:14 pm
Many thanks tulamide,
Sometimes I guess I just wake up and leave my brain on the pillow.
BobF
Postby Wassaka » Sat Apr 22, 2017 8:30 pm
Hi all, It would be well to implement a new GUI module: Blur (Diffumination). This would be applied in bitmaps or If possible in real-time view.
Wassaka
Postby Spogg » Sun Apr 23, 2017 9:21 am
Wassaka wrote:Hi all, It would be well to implement a new GUI module: Blur (Diffumination). This would be applied in bitmaps or If possible in real-time view.
I've been wondering what this could be used for...
Postby tulamide » Sun Apr 23, 2017 5:37 pm
For GUI control. For example, one could point the user to the current active area by blurring the rest. But a blur effect can't be realized with GDI+, it would need the help of a graphics card's shader.
Postby Wassaka » Sun Apr 23, 2017 10:01 pm
I wanted it to use it in pop-ups like About or similar.
Wassaka
PreviousNext
