How To Make Feedback Delay Ping Pong
• Page 3 of 3 • 1, 2, 3
Re: How To Make Feedback Delay Ping Pong
Sorry I wasn't clear. I can't pack a mono4 signal into a mono4. So since this effect was utilizing mono4's already I can't run a mono4 signal through it. Just a frustrating limitation.
- Perfect Human Interface
You'll have to decide whether it would be more optimal to turn the ping-pong echo part into multi-input stream (like L-stream R-stream) or leave it in mono4 processing and do more of them parallel. Or you can build custom sse-processor that has 512 wide registers instead of 128 and new set of sse instructions so you can run mono16
- KG_is_back
KG_is_back wrote:Or you can build custom sse-processor that has 512 wide registers instead of 128 and new set of sse instructions so you can run mono16
Honestly that's what I was thinking. Only problem is I can barely program a ping-pong.
What I use is sse, and just a panner inbetween channels, can do pretty neat 3d stuff. next up position
192k @ 8ms
MegaHurtz - Posts: 105
Users browsing this forum: No registered users and 42 guests
