How To Make Feedback Delay Ping Pong
Re: How To Make Feedback Delay Ping Pong
Postby Perfect Human Interface » Thu Feb 06, 2014 1:56 am
Sorry I wasn't clear. I can't pack a mono4 signal into a mono4. So since this effect was utilizing mono4's already I can't run a mono4 signal through it. Just a frustrating limitation.
Postby KG_is_back » Thu Feb 06, 2014 8:02 pm
You'll have to decide whether it would be more optimal to turn the ping-pong echo part into multi-input stream (like L-stream R-stream) or leave it in mono4 processing and do more of them parallel. Or you can build custom sse-processor that has 512 wide registers instead of 128 and new set of sse instructions so you can run mono16 :-D
KG_is_back
Postby Perfect Human Interface » Thu Feb 06, 2014 9:30 pm
KG_is_back wrote:Or you can build custom sse-processor that has 512 wide registers instead of 128 and new set of sse instructions so you can run mono16 :-D
Honestly that's what I was thinking. Only problem is I can barely program a ping-pong. :lol:
Postby MegaHurtz » Mon Feb 10, 2014 5:56 pm
What I use is sse, and just a panner inbetween channels, can do pretty neat 3d stuff. next up position :D
192k @ 8ms
MegaHurtz
Previous
Users browsing this forum: Google [Bot] and 15 guests
