ODD's and EVEN's in ASM
Re: ODD's and EVEN's in ASM
Btw good that you referenced control signal...
I should probably rename the "impulse" label in my synths Noise Velvet osc GUI... to just "pulse"... makes more sense
- R&R
R&R wrote:So... putting this beside your Velvet Noise won't cause a double inital impulse/burst at some point? Iow if they output at the same time?... Or does the velvet noise never output on the first/ealiest samples, ever?
If velvet noise does output on for example sample 1 to 16... I could just add a delay on it, but seems a little costly.
The way I coded velvet noise the first pulse never occurs on the first sample.
martinvicanek - Posts: 1322
LOL
Seems that way, I couldn't even force it to do that.
So... Solid assemblying on your part
- R&R
Looks like I'll have to add a delay anyway
Didn't think of it but realized my amp envelope etc forces me to add atleast 512 (~12ms) sample delay to get the same pulse sound as the velvet noise (pulses do have zero attack times after all) (edit: Managed to get it down to 256 samples)
This time around I don't need the random ±1... I'll just add the impulse prim with a delay.
- R&R
Uploaded a new version 0.52...
To justify this without any significant changes I created an entirely new "night mode" theme for the synth. For all those who might be allergic to subtle colors
Aux Oscillator using Noise Velvet with S1 all the way to the left (pulse)... now triggers an impulse on new notes, as intended.
Edit: Managed to mess it up by accidentally disconnecting filter routing dropdown. Fixed now!
I've got lots of future fixes and improvements to tinker with later.
- R&R
