Auto Portamento
Auto Portamento
Postby Halon » Sun Jun 09, 2019 4:55 am
Hi. I've seen many synthesizers that have automatic Portamento mode besides regular Portamento. Is that possible with flowstone?
Cheers,
Espen.
Halon
Re: Auto Portamento
Postby adamszabo » Sun Jun 09, 2019 5:15 am
What is auto portamento?
adamszabo
Re: Auto Portamento
Postby trogluddite » Sun Jun 09, 2019 5:45 am
Do you mean where you get portamento only when notes overlap? If so, then yes, I'm pretty sure this has been done with SM/FS synths in the past, though I'm not sure if for a synth using the usual poly-streams or whether only for a strictly mono design.
Re: Auto Portamento
Postby Halon » Sun Jun 09, 2019 6:31 am
trogluddite wrote:Do you mean where you get portamento only when notes overlap? If so, then yes, I'm pretty sure this has been done with SM/FS synths in the past, though I'm not sure if for a synth using the usual poly-streams or whether only for a strictly mono design.
Yes that is what i meant. I guess it would only work in mono streams? Ive mostly seen this in mono synths tbh.
Halon
Re: Auto Portamento
Postby adamszabo » Sun Jun 09, 2019 11:29 am
That is called Legato mode and yes its possible
adamszabo
Re: Auto Portamento
Postby Halon » Sun Jun 09, 2019 12:09 pm
Thanks.
Halon
