Auto Portamento
Auto Portamento
Hi. I've seen many synthesizers that have automatic Portamento mode besides regular Portamento. Is that possible with flowstone?
Cheers,
Espen.
Cheers,
Espen.
- Halon
Re: Auto Portamento
Do you mean where you get portamento only when notes overlap? If so, then yes, I'm pretty sure this has been done with SM/FS synths in the past, though I'm not sure if for a synth using the usual poly-streams or whether only for a strictly mono design.
Re: Auto Portamento
trogluddite wrote:Do you mean where you get portamento only when notes overlap? If so, then yes, I'm pretty sure this has been done with SM/FS synths in the past, though I'm not sure if for a synth using the usual poly-streams or whether only for a strictly mono design.
Yes that is what i meant. I guess it would only work in mono streams? Ive mostly seen this in mono synths tbh.
- Halon
Re: Auto Portamento
That is called Legato mode and yes its possible
- adamszabo
Users browsing this forum: No registered users and 116 guests
