Stereo WAV file recorder (Ruby)
Hi all! I've made some changes to original mono wave recorder schematic found somewhere here. Now it supports mono /stereo recording not only streaming to disk, but also in memory (for slow hdd).
Also added an "Add" mode when recording appends to a previous one.
Could not make Add mode to work in disk record mode - that's why this mode works only in Disk Rec mode off.
Attached a simple delay to right channel to make stereo out of mono input. Hopefully will be of use to someone. I once stumbled upon somebody asking for this feature on StackOverflow, using the same Ruby wave class and mono wave recorder schematic..
- Wave file stereo recorder.fsm
- (93.17 KiB) Downloaded 33 times
HiAsm - A Visual Programming IDE for ALL programming languages:
https://hiasm.com
https://hiasm.com
User108 - Posts: 31
Re: Stereo WAV file recorder (Ruby)
I think I should add indication of memory usage when recording to RAM - by counting recording buffer array size. But not shure of exactness of this method, because arrays in Ruby also use some other information for self organization.
https://hiasm.com
https://hiasm.com
User108 - Posts: 31
