Better Stream Readouts
Because... the stock readout modules are a bit too simple, and I've been asked for...
These readouts support value hold (by click), and some more customization options in the property panel
Regards
Maik
Regards
Maik
MyCo - Posts: 718
Re: Better Stream Readouts
Could you also add integer and binary formats? I often pass my values as integers or binary masks between modules.
- KG_is_back
Very useful, many thanks!
KG_is_back wrote:Could you also add integer and binary formats? I often pass my values as integers or binary masks between modules.
I've added Hex/Binary/Integer as option. Download is in the first post
MyCo - Posts: 718
Thanks, could come in handy. Especially the Packed Poly readouts and the Poly Unpack module inside that I yoinked as well.
- Perfect Human Interface
