Better Stream Readouts
Postby MyCo » Tue Jun 23, 2015 1:03 pm
Because... the stock readout modules are a bit too simple, and I've been asked for...
Stream Readouts v2 (MyCo).fsm
(4.85 KiB) Downloaded 1169 times
These readouts support value hold (by click), and some more customization options in the property panel
Regards
Maik
MyCo
Re: Better Stream Readouts
Postby KG_is_back » Tue Jun 23, 2015 3:38 pm
Could you also add integer and binary formats? I often pass my values as integers or binary masks between modules.
KG_is_back
Postby Spogg » Tue Jun 23, 2015 5:00 pm
Very useful, many thanks!
Postby MyCo » Tue Jun 23, 2015 6:47 pm
KG_is_back wrote:Could you also add integer and binary formats? I often pass my values as integers or binary masks between modules.
I've added Hex/Binary/Integer as option. Download is in the first post
MyCo
Postby Nubeat7 » Tue Jun 23, 2015 7:18 pm
very useful, thanks a lot myco! :)
Postby Perfect Human Interface » Tue Jun 23, 2015 11:21 pm
Thanks, could come in handy. Especially the Packed Poly readouts and the Poly Unpack module inside that I yoinked as well. :)
