How to prevent a button to trigger when switch off?
Postby jjs » Thu Jan 02, 2014 3:36 pm
is there a simple solution to prevent a button to trigger again when switching off ?
I noticed that every time i switch a button off, there is another trigger send, but not always measurable with the triggercounter !?!? :roll:
Thanks for any help on this !
jjs
Re: How to prevent a button to trigger when switch off?
Postby tester » Thu Jan 02, 2014 5:54 pm
Yes, you can control triggers. There are "bool to true" and "bool to false" prims to do that.
Or like this. The "test design" here is because in one direction switching is active and on other - passive.
1trig.fsm
(4.36 KiB) Downloaded 902 times
tester
Postby jjs » Thu Jan 02, 2014 6:44 pm
Thank you for your help Tester !
I think i can implement this.
:D
jjs
Postby Nubeat7 » Thu Jan 02, 2014 8:08 pm
you also could use the triggerswitch instead..
Postby jjs » Thu Jan 02, 2014 8:29 pm
yes, but at the same time i needed to switch a selector.
But after all trouble......the extra trig when switching did come in handy :roll: (after rethinking the whole process), as it would trigger the save module to save also the last data which otherwise would be lost.
So thank you both for your input.
jjs
Postby tester » Thu Jan 02, 2014 8:58 pm
And also always pay attention to trigger order (these small black dots on green wires).
tester
