comparing 2 arrays (ruby)
I need to do one of two things:
a) compare 2 arrays of elements and get an output with 0's (element at index not equal) and 1's (element at index equal)
or
b) determine which elements on input array changed after single retrig, and get an output like described above.
I guess the (a) is easier to implement.
It would be like this:
array1:
11
9
3
40
5
array2 (= array1 after change)
11
25
34
40
7
output:
1
0
0
1
0
(no sorting, no duplicate removing). How to make it with ruby?
or
array1:
11
9
3
40
5
11
25
34
40
7
output:
1
0
0
1
0
Re: comparing 2 arrays (ruby)
I think I found something, but... How to push these values to output?
I mean - ruby window shows correct answers, but when I add "output..." then it outputs only 0's or nothing.
compare-ary.fsm- (384 Bytes) Downloaded 883 times
...not what I expected. Right now I can get this - works only with output changed to "string". But how to get simple array of 0/1 integers instead?
compare-ary1.fsm- (425 Bytes) Downloaded 875 times
Now just simply convert them.
compare-ary1.fsm- (465 Bytes) Downloaded 911 times
TrojakEW - Posts: 111
it is possible with just one map command too
for comparing things with 2 options the ternary operator ( ? : ) always comes very handy
it works like this:
(condition) ? (when true) : (when false)
it works like this:
output @in1.map.with_index { |x,i| x = x==@in2[i] ? 1 : 0 }
Nubeat7 - Posts: 1347
Thanks!
So this little schematic will detect which values in input array have changed (per cycle).
detect-valchange.fsm- (743 Bytes) Downloaded 924 times
