l need help
l need help
Postby madl » Wed Jan 15, 2014 11:08 am
i need fix this SEQUENCER with mouse
Schematic3.fsm
(1.96 KiB) Downloaded 870 times
madl
Re: l need help
Postby Nubeat7 » Wed Jan 15, 2014 2:27 pm
nice one madl, your mouse logic for getting index (16 parts over the lenght) was wrong you need to get lenght and divide it by the pieces you want, to get a proper index (then you also could change the size like you want).. same goes for y axis, but with y axis keep in mind that 0 is up and bottom is full height so normally everything is "upside down" because in our mind 0 is at the bottom :?
i fixed this for you, you can do the same for the grid in back to change the size like you want..
madl seq fix.fsm
(1.85 KiB) Downloaded 877 times
Re: l need help
Postby madl » Thu Jan 16, 2014 2:21 am
thank you Nubeat7
madl
Re: l need help
Postby RJHollins » Thu Jan 16, 2014 7:12 am
Was briefly checking out the NuBeat posting file ...
It seems that the mouse cursor and the 'boxes' are not lining up correctly [off by one in the vertical].
Re: l need help
Postby Nubeat7 » Thu Jan 16, 2014 8:19 am
i also forgot the set to -1 when rightclick.. fixed both and reuploaded it
Re: l need help
Postby madl » Mon Jan 20, 2014 7:58 am
thank you so mutch Nubeat7
great work
madl
Users browsing this forum: Google [Bot] and 13 guests
