Bring to font
Bring to font
Postby rustyou » Mon Feb 03, 2014 9:53 pm
Hello,
In the exemple (schematic1), i would like put à second picture in front and no replace by the second picture.
-----> when i clic on the switch, my second picture hide my knob....
How shall do it?
Thank you,
Schematic1.fsm
Exemple
(159.92 KiB) Downloaded 915 times
rustyou
Re: Bring to font
Postby tester » Mon Feb 03, 2014 10:47 pm
...Like this?
Pay attention to trigger order (yellow wires coming out of the visual node).
Schematic1b.fsm
(153.46 KiB) Downloaded 985 times
Schematic1a.fsm
(153.46 KiB) Downloaded 947 times
tester
Re: Bring to font
Postby rustyou » Mon Feb 03, 2014 11:19 pm
Hi !
Perfect ..
Who is the solution.....?
rustyou
Re: Bring to font
Postby tester » Tue Feb 04, 2014 12:19 am
If you look closely at these yellow wires/cables - sometimes they have small black dots on the beginning or at the end. These dots count so called "order of triggering", which means - first, second, third, and so on. First connected is on the bottom. Last connected is on the top. Now if somewhere there is a selector/multiplexer, then this content can be turned off or on, but the content will be always on the same layer.
Just play with connecting these yellow cables (connected to "V" nodes) in various combinations. Redraw module is the last one connected (top layer = refresh all below it).
And don't worry - it took me some time too, to understand that.
tester
Re: Bring to font
Postby rustyou » Tue Feb 04, 2014 6:14 pm
hi Tester,
Thank you, I just realized !!! :)
It's not easy in the first time ... ^^
rustyou
