A new chorus-like effect
Re: A new chorus-like effect
Postby martinvicanek » Fri Oct 25, 2019 11:00 pm
This one will compile with FS 3.0.6, FS 3.0.8.1 and FS 4. ;)
Chorous_kbGui2_FS4_compatible.fsm
(744.11 KiB) Downloaded 1263 times
Note: The string "hop" apparently has a special meaning in FS 4 assembly. Unfortunaltely I use the following syntax a lot in my schematics:
mov eax,ecx; and eax,<2^n - 1>; cmp eax,0; jnz hop;
    <hopped code here>
hop:
This is OK in FS 3 but not so in FS 4. Simply change both occurrences of "hop" to "hop1" and it wll work in FS 4.
Postby wlangfor@uoguelph.ca » Mon Nov 25, 2019 3:23 am
Thanks Martin, very slick; I'll try and find a use for it :)
My youtube channel: DSPplug
Postby martinvicanek » Wed Nov 27, 2019 11:05 pm
Here is a variant I named "Korus". I like the sound better than Chorous. It uses more than a thousand randomly detuned echos. Check it out and tell me.
Thanks Kevin for the GUI!
Korus_kbGui2.fsm
(740.71 KiB) Downloaded 1238 times
Postby k brown » Thu Nov 28, 2019 4:21 am
(post deleted) I guess Martin didn't think my joke was very funny - sorry.
Postby Spogg » Thu Nov 28, 2019 12:29 pm
It’s great and Kevin has made it look really pretty too.
I compared it with the original Chourus and I don’t feel it’s inherently “better” (using my voice as a test source). To my ears it simply sounds different somehow, but it’s no bad thing to have a choice of sound.
Maybe it would be worth having a selector to choose the algorithm…
Brilliant work as always Martin! :ugeek:
Postby k brown » Thu Nov 28, 2019 10:19 pm
Fixed the jittering Rate slider track illumination, centered it's indicator line (now fixed in Chorous as well) and corrected the plugin name to Korus.
Korus_kbGui2b.fsm
(967.75 KiB) Downloaded 1213 times
I do like this better than Chorous - I'm using it with synths, not voice input, and to my ears, Chorous was adding a slight 'sproing-y' coloration to everything, and this isn't. At low Rate settings and Mix levels, it adds a beautiful, subtly-moving spatialization.
Postby Halon » Sun Dec 15, 2019 5:56 pm
Here is mine. Hope you like it.
MV Chorous.fsm
(414.2 KiB) Downloaded 1201 times
Halon
Postby Spogg » Mon Dec 16, 2019 9:32 am
I built the Chorous into my current synth project but found the CPU much higher than the Korus. I was better able to compare the sound between the two and, on a synth, the Korus is just as good to my ears.
So Korus it will be!
Thank you Martin!
Yet another Chorus
Postby martinvicanek » Sun May 10, 2020 5:24 pm
Yet another chorus effect. This one is pretty much straight forward: a configurable number of echos (up to 100) with random detunig and panning. It is a bit CPU hungry when you go to 100 voices but I like the sound.
anotherChorus.fsm
(36.49 KiB) Downloaded 1082 times
Postby k brown » Sun May 10, 2020 6:00 pm
You're becoming a regular chorus of choruses!
