How do you make FS save fonts?
Postby djbrynte » Mon Feb 10, 2014 5:23 pm
If im gona use a font in Flowstone. How do you make so the synth save that font. Because before i remember when i load the plugins with diffrent fonts then windows changed back to arial?
djbrynte
Re: How do you make FS save fonts?
Postby Drnkhobo » Mon Feb 10, 2014 6:39 pm
Hey man, just include the font in your install packager. Let it install it for you ;)
Drnkhobo
Postby Nubeat7 » Mon Feb 10, 2014 10:31 pm
is there no way to save fonts within the schematic?
Drnkhobo wrote:Hey man, just include the font in your install packager. Let it install it for you
i dont think that this is a common way, that the installer installs some fonts on your system, or?
Postby Nubeat7 » Mon Feb 10, 2014 10:45 pm
maybe the alternative typefaces input on the font primitive is here for situations when some special font isn`t installed on the users computer to give it an alternative font for this case? sadly the component reference is not up to date like so often :x
Postby RJHollins » Tue Feb 11, 2014 1:10 am
There could also be some copyright issue with fonts ...
Still ... adding fonts to a users system via an installer might trigger 'permissions' types of concerns.
When I want to include 'special fonts' in my project ... I've been using the 'Background Render Kit' that was posted [maybe from the SM forum]. Basically, I have the custom fonts on my system, but use a snapshot graphic to capture the look and use that to display. This way, I know that the graphic will display the same.
I've not tried the 'alternative font' option ... good to know about that.
Users browsing this forum: Google [Bot] and 17 guests
