Ruby Ticker
Ruby Ticker
Hi, I have been using the ruby ticker without understanding the code, and now I have to write a description for it (for a report), could anybody give me a hand? I´d highly appreciate.
-Alex
-Alex
def init
# Time step in secs
@step = 0.1
# Whether the timer has started ticking
@ticking = false
def event i,v,t
case i
when 0
if !@ticking && @state
@ticking = true
input 100,nil,t+@step
when 100
if @state
@step = 0.001 if @step <= 0
output 0
else
@ticking = false
- Alexandre
Re: Ruby Ticker
Key to understanding it are:
1) The 'event' method is called every time an input changes. It knows which input changed (i), a value (v: not used here), and the time when the event happened (t).
2) The 'input' method creates an input event that looks exactly the same as if a real input had changed. The input in this case is number 100 - this doesn't really exist as a component input, but Ruby doesn't care about that. The final value 't + @step' says when this new event should happen (it's bigger than t, so must be in the future).
So every time a 'tick' happens, the Ruby code sends out an input event to make another 'tick' happen a little bit in the future. The rest is just logic for turning the ticker on and off.
Re: Ruby Ticker
Thanks, I think I got it now.
It also helped me understand some other examples ("Ticker - Custom" included with FS, and also AdamzCounter found elsewhere in this forum).
Funny that the input cannot be 1 on the example above (has to be 100, or 10, or 2, but not 1).
- Alexandre
Re: Ruby Ticker
You're welcome!
In fact, it could be, so maybe you understand more than you give yourself credit for! It just has to be a number bigger than the last "real" input (100 actually wastes a bit of memory in the RubyEdit, because the array of input data [@ins] takes up space for the missing inputs 1..99).
Alexandre wrote:Funny that the input cannot be 1 on the example above (has to be 100, or 10, or 2, but not 1)
Re: Ruby Ticker
Just for clarity: It can be any input that is not used already. So, if you have 2 inputs in use, index 0 and 1 can't be used, but index 2 would be available. In the DSPR modules, a high index was chosen probably to prevent any multiple use of an input (a user might add inputs to extend functionality, etc)
Re: Ruby Ticker
Yes, now I got it, 100%
Thanks trog and tulamide!
Simplest possible Ruby ticker below.
- Alexandre
Re: Ruby Ticker
Consider the first example. If it´s set to a period of 60 seconds and we change it to 1 second then it can take up to 60 seconds to update.
To fix this I will use the attached one for my project.
Thanks,
Alex
Thanks,
Alex
Alexandre Ticker 3.fsm- (27.34 KiB) Downloaded 906 times
- Alexandre
Re: Ruby Ticker
Somehow I forgot about the usual "trigger div" component... I could have just used a trigger div instead of what I did above
- Alexandre
