Filled graph triangles for dropdown lists
Hi all, I go so annoyed with having to use fonts or hollow triangles for dropdown lists that I decided to make a system by using co-ordinates and the graph line primitive by specifying the filled colour.
Unless I was to set x-co-ordinates however, I doubt I would be able to do this without the use of the rotate primitive,
So, enjoy these triangles which are a nice alternatives to lines and to the webdings font.
- custom arrows.png (15.56 KiB) Viewed 23629 times
Re: Filled graph triangles for dropdown lists
Really useful Robert, and nicely scaleable too!
Thank you!
Thank you!
Spogg wrote:Really useful Robert, and nicely scaleable too!![]()
Thank you!
here here, thanks. Nice to leave those webdings and line arrow hacks behind lol.
Very tidy!
Very cool Robert! Very useful , goes right into the tool box.
Thanks, BobF.....
Thanks, BobF.....
- BobF
Thank-you !
BobF wrote:Very cool Robert! Very useful , goes right into the tool box.
Thanks, BobF.....
RJHollins wrote:Thank-you !
k brown wrote:Very tidy!
You guys should check out My new sampler code too, it only uses 2% CPU for 40 samples at a time. Also, I found if you use mixpad or maybe wavepad by NCH software, you can save the Wav with MP3 like bitrate and it loads fine in the newer versions of flowstone.
The difference is 88% in size, talk about sampler madness!
What sampler code ?
lalalandsynth - Posts: 600
lalalandsynth wrote:What sampler code ?
here:
http://dsprobotics.com/support/viewtopic.php?f=2&t=34630&hilit=flowstone+game#p105542
make sure to also keep in mind that by using NCH wavepad or mixpad you can save wav files that work in the alpha that are only 2-3% of the original size that work in the alpha! Just use MP3 codecs for wav.
Makes putting together a commercial sampler even more realistic with that in mind.
