Conditional selection
If one wants to stay with DSP code component, how to code conditional selection?
pseudo code:
Any examples out there?
pseudo code:
switch value
case (1, 3, 5, 7)
otherwise // 2, 4, 6, 8
- juha_tp
Re: Conditional selection
I believe its only possible with assembler
- adamszabo
I did look that thread earlier but, could not find examples of usage since I need to make at least four operations (calculate coefficients using degree 3 polynomial equations) when the condition is true instead of just making one operation.
I guess "if" type statement could work if condition is checked for every coefficient calculation operation:
if(x % 2 != 0) a0 = polynomial
if(x % 2 != 0) a1 = ...
if(x % 2 != 0) b0 = ...
if(x % 2 != 0) b1 = ...
if(x % 2 == 0) a0 = ...
Could this be possible ... ?
- juha_tp
That would use way too much cpu, since it still calculates all your equations even if they are not "enabled"
- adamszabo
First thing that came to my mind was cubic interpolation, but you wouldn't need any conditionals for that, and it seems to be code for a filter. Maybe if you elaborate on the topic? Maybe there is another way?
Simple example, if you're only interested in every second sample, you could use hop(2) and had no need for the conditionals anymore.
I'd love to know the answer to this as well.
What I'm trying to do is a LR crossfeed plug-in without Ruby code. I'm using polynomials to calculate coefficients (in attached example I'm using BLT based implementation).
There's also something wrong with the LPF filter.
EDIT: attached the schematic
Linkwitz-Riley Crossfeed_unfinished.fsm- (1.83 KiB) Downloaded 1514 times
- juha_tp
Its best if you post a schematic because we have no idea which filter you are using that is different from the left or right channel, these graphs dont really tell us anything
- adamszabo
OK, updated my previous post with schematic.
- juha_tp
