Trigger Toggles and Dual Sample & Hold
I kind of wanted these so I made them. As with anything I make, they may not be the most elegant solution but I hope they're useful.
The first two modules toggle between two inputs whenever a trigger is received. The second module has two separate trigger inputs-- it will toggle to the top or bottom input depending which is triggered. The final module is like the second, but with sample and hold prims built-in. So it is effectively a two-headed sample and hold (rawr). Hopefully.
They should work with any green input.
Let me know if I did anything stupid.
Or brilliant... I'll take that too.
TriggerToggle_DualSampleHold_by PHI.fsm- (1.67 KiB) Downloaded 1113 times
- Perfect Human Interface
Re: Trigger Toggles and Dual Sample & Hold
There are much simpler ways to implement all 3 of them using trigger blocker prims.
TriggerToggle_DualSampleHold_by KG.osm- (625 Bytes) Downloaded 1119 times
KG_is_back wrote:There are much simpler ways
Oh of course there are.
People like you are why I gave up programming. Seriously though, thanks. I'll use these simple versions.
I added the help text and my little GUI indicators because I think they're important for debug/visibility (and they're easy to take out).
TriggerToggle_DualSampleHold_by KG.fsm- (1.17 KiB) Downloaded 1123 times
I was sure Last Switched didn't work like that.
I thought the value actually had to be different (as with the "changed" primitive-- the tooltip uses the same wording), not that it just waited for triggers. Of course it's not written in the manual either.
Another thing I wish I had known a long time ago...
