DSP: possible to split audio to 2 volume levels? peaks and..
Re: DSP: possible to split audio to 2 volume levels? peaks a
Postby mayo » Mon Jun 15, 2020 9:57 am
Spogg wrote:I was thinking about this all wrong! :oops:
If you have a loud signal it can’t be quiet at the same time (unless Schrödinger was involved). :lol:
So, you use an envelope follower of your choosing (peak/rms etc.) and the side chain value created is used to route the incoming signal through one effect channel or the other.
The routing (multiplexing in effect) should be “soft” to avoid sudden shifts. So at say -12dB channel A gets the whole signal and at say -6dB channel B gets the whole signal. In between those crossover levels the signal is shared, so at -9dB both channels get an equal amount of the signal.
At the end of the 2 processing chains the signal is combined.
I think that approach would work and be quite useful and potentially interesting.
yes this sounds good, nice idea, do you think you can make also schematics for that? of course if you are interested in this project and find it usefull in your work /and have some free time. I think this processing can be very usefull in making plugins / processing audio, because usually you want to process just peaks (in mixing/mastering) not to distort or shape whole signal (most techniques like saturation, compression, limiting want just to remove sharp digital peaks, round them etc.)
mayo
Postby Spogg » Mon Jun 15, 2020 11:47 am
Since I don’t make actual music I wouldn’t personally have a use for it. Plus I’m really busy with several projects at the moment.
However, if nobody else wants to step up, I’ll put it on my to-do list because it does kind of interest me.
Reverb/echo on just the loud parts?
Postby k brown » Mon Jun 15, 2020 4:16 pm
Pretty sure your idea is how multiband compressors work. Could use it for compression, EQ, whatever.
Postby tulamide » Mon Jun 15, 2020 4:27 pm
Spogg wrote:Reverb/echo on just the loud parts?
If given the opportunity, I'd put them on the quieter parts!
In general, I see the possibilities with this technique (could fully imagine it after MichaelBenjamin talked about sidechaining), but can't help.
Kevin, multiband compressors work by splitting the signal into frequency bands, independend on their amplitude level.
Postby Spogg » Tue Jun 16, 2020 7:35 am
I’m getting progressively more interested in this idea…
Different filtering on the loud parts and quiet parts?
Postby trogluddite » Tue Jun 16, 2020 1:17 pm
Once you have a regular gate, most of the hard work is done, surely? A gate with envelope-time control already generates a "gain" signal with which to multiply the source. All you need to get the "below threshold" part is the opposite gain - maximum when the gate is "closed" and minimum when "open" - i.e. signal * (1.0 - gain).
Here a very quick modification of the stock gate which should give us a starting point...
hi_lo_splitter.fsm
(21.45 KiB) Downloaded 1506 times
That only a first blush, of course. Two possible improvements come immediately to mind...
- More control over the "crossfade" - maybe this "linear" crossfade would not be ideal in all cases?
- "Look ahead" to ensure that very fast transients are handled correctly at short attack times.
Postby mayo » Mon Jun 22, 2020 2:06 pm
trogluddite wrote:Once you have a regular gate, most of the hard work is done, surely? A gate with envelope-time control already generates a "gain" signal with which to multiply the source. All you need to get the "below threshold" part is the opposite gain - maximum when the gate is "closed" and minimum when "open" - i.e. signal * (1.0 - gain).
hi_lo_splitter.fsm
Thank you very much, I was experimenting with simmilar method using gate and phase inverse, with little bit different sound results.
mayo
Postby mayo » Mon Jun 22, 2020 2:08 pm
some of you asked what is use of this splitter: many uses - for example some analog devices works different in low signal and dirrefent for peaks/transients (like tape etc.) so for emulation analog hardware, tapes, etc. to use different type of saturation for lower signal and for peaks.
mayo
Postby mayo » Sun Jun 28, 2020 12:08 pm
https://oeksound.com/plugins/spiff/
this is perfect example for what transient / below splitter is perfect for
but it is splitting transients part somehow better than our techniques , more cleaner, more detailed
do you have idea how they made it?
mayo
Previous
Return to DSP
cron
