Denormals
Denormals
Postby tulamide » Thu Sep 18, 2014 5:39 pm
I'd like to ask about opinions:
If there are denormals, cpu load raises. As an example, in a schematic the idle load is 0.6%. With denormals occuring the load raises to the same value as playing a note, 1.8% in this case. So, denormal remover is the solution, right? Well...
Introducing denormal remover adds to the cpu load, too. With that module the idle load raises from 0.6 to 1%, which is near to double the amount, while not even halving the denormal load. Should it be used nevertheless, or is there a less cpu heavy solution?
Re: Denormals
Postby KG_is_back » Thu Sep 18, 2014 7:10 pm
Don't use the stock denormal remover. Rather add a few lines in the code to remove denormals. Algorithms that involve some feedback loops (filters, envelope followers) are prone to denormals.
KG_is_back
Re: Denormals
Postby tulamide » Thu Sep 18, 2014 7:35 pm
I see. Thanks KG!
Would it be sufficient to just cut everything (by setting it to 0) below a certain threshold?
Re: Denormals
Postby Xtinct » Thu Sep 18, 2014 7:59 pm
you could use something like
out = in&(abs(in)>1e-06);
but I think that's like decapitation to cure a headache :D
Xtinct
Re: Denormals
Postby KG_is_back » Thu Sep 18, 2014 8:40 pm
tulamide wrote:I see. Thanks KG!
Yes, that is a common way to do it. In fact RBJ filters have a very efficient way to do it inside.
float abs=0
stage(0){
  abs = 3.4e38|0.999999|0.1; //this is a bitwise mask that has all bits on except the first (most significant) one
//when you apply this mask via & (and) to a float number, you remove the sign so it is the cheapest way to do abs(x)
var = ((var&abs) > 1e-11)&var;
KG_is_back
Re: Denormals
Postby tulamide » Thu Sep 18, 2014 9:01 pm
KG_is_back wrote:Yes, that is a common way to do it. In fact RBJ filters have a very efficient way to do it inside.
float abs=0
stage(0){
Everything below -220 dB (1e-11) should indeed not produce any meaningful data, so that should be safe. But is it reliable, too? I mean does the comparison recognize denormals as being denormalized? I'm a bit coinfused beacause I read this article about the topic: http://www.musicdsp.org/files/denormal.pdf
Starting at chapter 3 ("Solutions") there are quite some different ways described. All of them in C++, which is why I don't know how to do that in dsp code. But especially 3.1.1 and 3.1.2 sound like it should be doable somehow. If so, than 3.1.2 should be the fastest method. Would you mind having a look at the pdf?
Re: Denormals
Postby tulamide » Thu Sep 18, 2014 9:02 pm
Xtinct wrote:but I think that's like decapitation to cure a headache :D
:lol:
But that's actually what I was thinking of, too.
Re: Denormals
Postby KG_is_back » Thu Sep 18, 2014 9:23 pm
tulamide wrote:Everything below -220 dB (1e-11) should indeed not produce any meaningful data, so that should be safe. But is it reliable, too? I mean does the comparison recognize denormals as being denormalized? I'm a bit coinfused beacause I read this article about the topic: http://www.musicdsp.org/files/denormal.pdfStarting at chapter 3 ("Solutions") there are quite some different ways described. All of them in C++, which is why I don't know how to do that in dsp code. But especially 3.1.1 and 3.1.2 sound like it should be doable somehow. If so, than 3.1.2 should be the fastest method. Would you mind having a look at the pdf?
Denormals are not immortal demons... they are numbers like any other. Comparison works for them the same way as normal numbers - you can add them, multiply them and compare them like normal values.
Solution 3.1.1 is terribly inefficient. It is just a stupid way, to compare x with largest denormal value by splitting float into two integers. and then making value zero if its smaller.
Solution 3.1.2 is very simple and elegant, but it not only removes denormals (and very small number as such) - it removes all decimal values below certain point. Because after adding and subtracting the number is rounded.
example:
v=0.000123456789
v=v+0.01
v=v-0.01
now v=0.00012345700
The solution by comparating abs(value) with small number is optimal - it preserves the number in full quality and actually it is identical with solution 3.1.1 if you choose the small value to be next to denormal. In praxis you what to remove value even if it only gets close to denormal range, because further processing can turn it into denormal. Imagine you have a filter that outputs value very close to denormal and you pass that value to amp which makes it even smaller... BOOM denormals...
KG_is_back
Re: Denormals
Postby tulamide » Thu Sep 18, 2014 9:58 pm
Thank you very much for this detailed explanation. I could follow it and understand the logic. Finally.
I will use the abs method. Thanks, KG :D
Re: Denormals
Postby tester » Thu Sep 18, 2014 11:34 pm
Will/would such portion of code change something (CPU usage) in (where in the design where? input?) zdf filters posted somewhere here?
tester
Return to DSP
cron
