Midi GUI Keyboard
Midi GUI Keyboard
Postby Loopeytunes » Sun Oct 26, 2014 4:29 am
DJBrynte asked for a keyboard module a few days ago and I made a quick keys module for him.
Here it is:
Loopeytunes Keys v1.3.fsm
(14.83 KiB) Downloaded 1424 times
Update Log 27-10-14
Added:
- Set keys corner radius.
- Gradients on keys.
- Turn on or off the gradient.
- Transparency on the "Pressed" colour.
- Black key highlight gradient.
- Turn on or off the black key highlight.
Bugs Fixed:
- N/A
Update Log 26-10-14
Added:
- Redraw limiter (added by Exo)
Bugs Fixed:
- Double Trigger Note event when mouse clicking.
I will update this (when I get the chance) and add more user customization in it.
Loopeytunes
Re: Loopey Keys
Postby djbrynte » Sun Oct 26, 2014 11:04 am
still not working with selectors? :/
djbrynte
Re: Loopey Keys
Postby Nubeat7 » Sun Oct 26, 2014 2:38 pm
hi loopey tunes,
your keyboard doubletriggers note events,
you should choose between mLDown/Up or the drag on/off bool to trigger note on/off events instead of using both.
Re: Loopey Keys
Postby Loopeytunes » Sun Oct 26, 2014 2:42 pm
Thanks, I'll take a look at it later today and fix it.
Loopeytunes
Re: Loopey Keys
Postby Exo » Sun Oct 26, 2014 3:43 pm
Hi Loopey,
I fixed your keyboard so that it works with the old selector. It will need some more testing though because I am using the Thread primitive which is R&D, and I currently don't have a midi keyboard to test if it works with 'real' Midi.
Loopeytunes Keys v1.1.fsm
(8.95 KiB) Downloaded 1238 times
Exo
Re: Loopey Keys
Postby Loopeytunes » Sun Oct 26, 2014 3:59 pm
EDITED:
Ok my mistake, I turned the wrong MIDI device on lol it does work with "Real" MIDI.
Loopeytunes
Re: Midi GUI Keyboard
Postby Exo » Sun Oct 26, 2014 4:22 pm
Try this one...
Loopeytunes Keys v1.0fix2.fsm
(9.1 KiB) Downloaded 1281 times
Exo
Re: Loopey Keys
Postby Exo » Sun Oct 26, 2014 4:23 pm
Loopeytunes wrote:EDITED:
Lol the new one I just posted is probably better anyway (if it works fine) because it doesn't rely on the Thread primitive.
Exo
Postby Loopeytunes » Sun Oct 26, 2014 4:31 pm
Yep that works :)
I've sorted the double trigger note events problem that Nubeat7 mentioned, thanks :)
Used your fix Exo and updated the file in the first post. Thanks :)
Loopeytunes
Postby Exo » Sun Oct 26, 2014 4:34 pm
Loopeytunes wrote:Yep that works :)
Great, thanks for sharing the keyboard :)
Exo
