Pad selectors(or "radio" selectors)
Re: Pad selectors(or "radio" selectors)
Postby Nubeat7 » Tue Nov 04, 2014 8:16 am
well, the preview in the properties is a great feature, i always forget about this.. :)
Postby djbrynte » Tue Nov 04, 2014 9:24 am
great work!
djbrynte
Postby billv » Tue Nov 04, 2014 10:17 am
Note Small Bug :
(.to_f) needs to be removed twice in code..
output 'altVal', @altValue[@sel].to_f
the conversion to float in the alt_value output prevents string/int output ...
billv
Postby Nubeat7 » Tue Nov 04, 2014 1:36 pm
yes, thats a question of what you need as alternative outputs, i took .to_f because i thought that this would be a common use for it, but sure if you need string you don't need to add anything and you can get rid of the ".to_f" also if you need int but if you need floats you need to add ".to_f" maybe you could just comment it, so it just nneds to be uncommented when floats are needed...
it also depends if you are using the ruby value, then it will always be sent as string if you don't convert it, while if you use green outs, the outs would convert it, then you dont need to add anything..
alternative to make it userproof you could make a selector in the properties and output with cases...
Postby Nubeat7 » Tue Nov 04, 2014 1:57 pm
just like this..
Pad Selectors_nubeat2.fsm
(84.4 KiB) Downloaded 1060 times
Postby billv » Tue Nov 04, 2014 9:41 pm
Nubeat7 wrote:make it userproof you could make a selector in the properties and output with cases
yeh,much more practical...Nice.. :)
billv
Postby billv » Fri Dec 05, 2014 11:22 am
taking nubeat7's mod a little further, and a bit closer to Trog's example that
inspired the initial idea, here's one with rows and columns..
Pad Selectors_BV_RowsandColums.fsm
(99.57 KiB) Downloaded 1072 times
billv
Postby RJHollins » Fri Dec 05, 2014 2:52 pm
fantastic billv !
8-)
Postby billv » Sun Dec 07, 2014 1:29 pm
Thanks RJ.
I found also by changing the order of just two lines of code, instead of incrementing
on the Y axis, can do the X axis as well. The whole module just "flips" around... :lol: :D
So I re-uploaded it...you can set the new "Direction" parameter in properties.
Cleaned up the code a bit....
billv
Postby Walter Sommerfeld » Wed Dec 10, 2014 12:26 pm
Hi billv,
awesome part this RowsandColums.fsm...!
Can u change it 4 me so i can (de-)select multiple pads while dragging ?
cheers,
Walter
Walter Sommerfeld
