Why don't i have access to 2019 version?
Postby Matth23u » Fri Aug 21, 2020 3:16 am
The latest version i can get is 2016 but i registered in 2019. I won't renew before a while but i thought i should have access to the versions released during the matching year of purchase.
Matth23u
Re: Why don't i have access to 2019 version?
Postby tulamide » Fri Aug 21, 2020 4:22 am
Nothing was released since 2016, therefore you have the latest version. The leatest release was 3.0.8.1, but it is recomended to use 3.0.6 to avoid some slowdowns introduced with 3.0.8.1
Postby Matth23u » Mon Aug 31, 2020 6:06 am
1Oh okay, will 64 bit ever be released?
2And exported VST midi ins and outs made available in hosts and in VST's list?
3I've found a software named JBridge, do you believe it could fix both?
4Do you believe FL Flowstone can be loaded on JBridge or adapted for FL's 32>64 adaptor wrapper that works on some other VSTs?
5Do you believe you could make component packs for sale, and invite the best developers of previous generations of Flowstone synths to sell their work by the same process?
Matth23u
cron
