Pad selectors(or "radio" selectors)
Re: Pad selectors(or "radio" selectors)
@kortezzzz...
If you can isolate the issue with Trog's radio, stick it in example fsm and up it to General section,
I'm sure the gurus can probably sort it out if Trog's busy/not around...
Just saw this note...
Well I'm fine with it. The plugin that uses this module has been released already, but must say I had to make lot's of tweaks to match it to my design.
You can see the results in the product page at my site:
http://www.tornsub.com/ProductDetails.aspx?pid=4
kortezzzz - Posts: 763
I just had a weird afternoon after work, everything i tried in FS worked..really strange..
Here's the latest...
@Walter..
Your "Left mouse delete" is there...
In properties there is a question.."Left mouse delete as well?"... answer no or yes..
The accurate mouse capture is installed.
(If you have used the Painting canvas, you might have noticed the delivery of the
mouse capture is not real fast...this slight delay is even more noticeable with this
module when large grids are used) ..Still works..just a bit sluggish...
I wasn't sure if Walter wanted Gradient for the Foreground or the background, so..
Did the sensible thing...
For the foreground and the background you can select either..
Brush,Gradient, HatchBrush or Texture Brush...
Extra colors and controls for Hatch and Gradient..
The Texture brushs have an array of 30 textures included...(small bitmaps)...
....the module goes in/out of toolbox pretty smooth...
Bear in mind there's a lot of stuff in properties now...I didn't set up a "purging" routine...
So when you export...delete what you don't need to optimize, if you feel the need......
Known issues: dragging on borders turning on both sides.... and Preset String still being used..
@Walter..
billv wrote:and Preset String still being used..
What exactly are you trying to store using the preset string? I could think of a few ways, depending on your answer. I started the fsm, but, and I hope you forgive me saying that, it is a bit of a mess. It would take me some time figuring everything out (no indenting also isn't helping). It's easier if you just describe it in detail.
Btw., I'm working on something quite similar. But it isn't exactly this, it's more like the pads of a drum synth in functionality. I will publish it when done, maybe there's something in it that you can use for your project, too.
tulamide wrote:What exactly are you trying to store using the preset string
ATM I'm saving the 'selection' array via preset string... works fine...
But as pointed out earlier, arrays larger than 250 chr will have issues.....
So the VST parameter preset needs to replace the Preset String Prim...
I havn't got a result yet with that modification....that's all...
Ps:
Thanks for the tip that the fsm is a mess and hard to read/confusing....
Heard lots of similar complaint before...
billv wrote:Heard lots of similar complaint before...Will stop uploading.
That would be a shame. I mean, those who are using your module are only interested in that it is working, and won't need to take a closer look.
I just offered my help, so I'm quite confused from your answer. It reads as if you're angry about my offer. I was thinking about bitmasking the state of the pads. That way, 1024 pad-states would fit into one 128-byte string, which is easily storable as a preset string. But if you want to do it on your own, that's fine. A simple "Thanks for the offer, but I prefer to figure it out on my own" would have been sufficient then.
tulamide wrote:It reads as if you're angry about my offer
No not at all...that's why i went back and deleted the "Will stop uploading" comment.
Was written in haste, not explained well....so easily taken the wrong way....
Thing is, I actually thought i did good job making the code readable.
I don't know, i seem to writing ruby in "another language", so to speak.
This is magnified even more when i see other peoples code...and it looks nothing like mine..
So I'm thinking, should such code be in "examples"..will it lead other 'noobs' into bad
practices, and bad coding habits....makes sense....examples should be examples,
not confusing noob experiments like mine that always seem to be faulty.
billv wrote:I don't know, i seem to writing ruby in "another language", so to speak.
Oh, then I'm very sorry to have hit a trigger.
Regarding "it looks nothing like mine". That's not true. It is just a bit syntactic structure and one or the other comment, that's missing. Nothing spectacular. But if you haven't written the code, you start at zero and try to both, read the code and understand the developer's thoughts. And that can be tough sometimes. For example, when identation is missing.
It would be a shame to not upload anymore. You always come up with awesome ideas (like your canvas).
tulamide wrote:Oh, then I'm very sorry to have hit a trigger.It wasn't on purpose
with FS. A few weeks back, I went through "nil error" HELL for about 3 days, and it really done
my head in
tulamide wrote: It's totally normal to have issues in posted examples
Yeh your right in a way...
tulamide wrote:bitmasking the state of the pads. That way, 1024 pad-states would fit into one 128-byte string
Not ignoring this....just too hard for to grasp ATM...
Wow billv - what a nice 2nd sunday in advent gift!
I know i`m sometimes a pain in the a.. but i have 2 ask here 4 a favour from u - again :
Delete while dragging just like selecting...!
You've outdone yourself.
I need(ed) this 4 emulating a light bulb as a source behind the pads/buttons...
I hope u can manage this 2...
cheers,
Walter
P.S.: I miss a reset/init after changing the rows and column size like 4x4... even after turn ruby on/off i have to set/reset all pads 2 get a proper output...
hint: implement the @grid.size into the Rand Array...
@Walter..
cheers,
Walter
Walter Sommerfeld wrote:I know i`m sometimes a pain in the a.. but i have 2 ask here 4 a favour from u - again :
No worries Walter....I'm happy to try any mod...just another excuse to learn more...
Do you want to do it all with just the left mouse, is that right?
Sounds like you want a draw behaviour like Myco did with my Matrix trigger back in SM..
If the first square you click is off, click or drag will turn all selection(s) on...
If the first square you click is on, click or drag will turn all selection(s) off...
I'm not familiar with Win 8 touch stuff....do you need right mouse stuff removed..?
Walter Sommerfeld wrote:I need(ed) this 4 emulating a light bulb as a source behind the pads/buttons..
Great. Glad that worked out.
I'm seeing a problem with the Texture setting in the b/g squares...mouse drawing slows right down..
Walter Sommerfeld wrote: Known issues: dragging on borders turning on both sides...
Yeh, this is annoying, and really needs to fixed, but might take me a while...
I've used a Logical "and" for the first time and its confusing me a bit...
Plan B is to up a small drawing example to general section, and get trained on how do
this inner/outer technique thing...work it out eventually...
Walter Sommerfeld wrote:P.S.: I miss a reset/init after changing the rows and column size like 4x4... even after turn ruby on/off i have to set/reset all pads 2 get a proper output...
Yes.. your right...was easy fix...in meantime, you can drop this straight in..
In def event, there a code block that starts with "if i == 7 or i == 13 then "
Replace the whole block with this'
@sizex = 2 if @sizex < 2
@sizey = 2 if @sizey < 2
nilerrors
@draw=[]
@posarray=[]
@posarrayaltvalue=[]
@boolarray=Array.new(@sizex*@sizey){|x|x = false}
@valuearray=[]
output 0,nil
output 1,[]
output 3, @posarray
output 4,@boolarray
output 5, @posarrayaltvalue
redraw
EDIT:
Also the mouse drag delete is wrong with the accurate mouse drag code...
Its not deleting each selection in order when you drag, it's just wiping the whole array..
EDIT2:
The grid size parameter is there inside the rand array...
def event i,v
@a = Array.new(16) { |x| x = (rand(0..127)) }
output 0,@a
watch @a
127 is used as the grid size here...
