DirectX
DirectX
Postby frank-riedel » Wed Sep 26, 2012 3:04 am
Is there a tecnic (code example) to send DirectX command to windows in Flowstone??
/Frank
frank-riedel
Re: DirectX
Postby frank-riedel » Mon Oct 22, 2012 9:21 am
Realy no one worked with this ??
/Frank
frank-riedel
Re: DirectX
Postby infuzion » Mon Oct 22, 2012 11:49 am
Apparently, we tend not to bother with DirectX.
infuzion
Re: DirectX
Postby CoreStylerz » Mon Oct 22, 2012 12:10 pm
Try to give a look to
http://ruby-opengl.rubyforge.org/
Open gl.
Ruby/Directx is not documented anywhere
PM me if you are interested.
CoreStylerz
Re: DirectX
Postby CoreStylerz » Mon Oct 22, 2012 12:11 pm
CoreStylerz wrote:Try to give a look to
Open gl.
The problem is that it uses ruby gems, so perhaps this will not work.
CoreStylerz
Re: DirectX
Postby frank-riedel » Mon Oct 22, 2012 2:28 pm
THX
GUYS
BTW - what is Ruby Gem ? - .
/Frank
frank-riedel
Re: DirectX
Postby CoreStylerz » Tue Oct 23, 2012 12:08 am
frank-riedel wrote:THX
GUYS
/Frank
"GEMS" are libraries for ruby. Parts of "code".
The same of when you install redistributable for C++, or when you call C standard libraries like .h files in the header.
For example, a programming launguage may translate a little portion of code just by wiriting little thing, without the need you write the function.
In ruby for example, you can write : ciao.reverse to get oaic
Obiviosuly the ruby interpreter call the standard function "reverse" that contain the piece of code that revert a string.
All standard functions could be called with default ruby. Like string functions or encoders etc..
But, not all is included in the standard. So gems are expansion of standard library.
Give a look to this :
http://rubylearning.com/blog/2010/12/14 ... y-and-how/
CoreStylerz
Users browsing this forum: Google [Bot] and 60 guests
