Newbie Starter Template (v.3.0.9)
Here is a weird one. If the module has only 4 samplers it works fine. If you duplicate them and try to add more sample players per module it craps out completely. CPU load also becomes 10 times higher. The ARPs also get completely out of sync. Works with v3.0.9b2-3319-gd51130b. Just don't save the samples inside the project file because it's duplicating them 4 or 6 times more. The UI still needs more adjustments.
SlimEchoDelay 001.fsm- The maximum delay is set at 480,000 samples. That translates into a maximum delay of 10 seconds at 48Khz.
- (159.77 KiB) Downloaded 1063 times
MonoSampler 028.fsm- I had to re-upload them because the alignment was wrong in the UI.
- (371.02 KiB) Downloaded 1083 times
MonoSampler 027.fsm- (280.87 KiB) Downloaded 1066 times
- newdsp
Re: Newbie Starter Template (v.3.0.9)
Here are some modifications I made to the SlimEchoDelay. Now it has option to invert the output. Works with v3.0.9b2-3319-gd51130b.
WaveArp 003.fsm- (275.8 KiB) Downloaded 1079 times
SlimEchoDelay 003.fsm- (183.63 KiB) Downloaded 1077 times
- newdsp
Here are some plugins that work with Reason 10 64bit. Not all of them are fully tested but most of them seem to work. For the most part. Unless the exported module has more than 1 pair of outputs. It that case it doesn't work with Reason 10. Use 7zip to extract the files or you can double click on the file and it should ask for a location where you want everything to be extracted. Pick either the Desktop or the VSTplugins folder. That should extract all the files to a folder named Reason Plugins. Let me know how it goes. Thanks.
https://drive.google.com/file/d/1OgJQyF ... sp=sharing
- newdsp
Here is another version of the WaveArp that actually works with Reason 10 because all the outputs are now rewired and limited to a single stereo pair. The other version that has 2 stereo outputs worked fine in FL Studio but it didn't work in Reason 10.
WaveArp 005.fsm- Works with FS v3.0.9b2-3319-gd51130b.
- (278.67 KiB) Downloaded 1078 times
- newdsp
And here is another prototype sampler for wave sequencing that needs tons of random modulations but I didn't have time to add any of those yet. Only random pan activated by a red led switch.
https://youtu.be/E5ch-DAYalg
https://youtu.be/8u_Ze_15g6E
WaveArp 010.fsm- (276.66 KiB) Downloaded 1063 times
WaveStepRSN.fsm- (1.88 MiB) Downloaded 1061 times
WaveStepV08.fsm- Works with FS v3.0.9b2-3319-gd51130b.
- (1.88 MiB) Downloaded 1067 times
- newdsp
Here a few ones that work Reason 10.
WaveArpRSN8.zip- (1.62 MiB) Downloaded 1068 times
- newdsp
Users browsing this forum: Majestic-12 [Bot] and 14 guests
