Quilcom Flooper Modified (Fun Looper)
Re: Quilcom Flooper Modified (Fun Looper)
Postby newdsp » Mon Jan 04, 2021 7:18 pm
Here is a super simplified Boss BR 80 version of the Flooper but it needs all the colors to be changed. I will try that later.
All the recorders are now mono but they have random panning at the output and also manual pan when the RATE is set to 0.
All Flooper modifications are found here:
https://drive.google.com/drive/folders/ ... 1Z2p91Gn1b
https://drive.google.com/drive/folders/ ... sp=sharing
Boss BR 80 v0.06.fsm
Added BPM delays. First delay is at 2x 1/16, next one at 4x 1/16, next at 6x 1/16 and the final one at 8x 1/16. They are hard coded at the moment but I will have to make it user configurable.
(3.17 MiB) Downloaded 1079 times
Boss BR 80 v0.05.fsm
Here is an updated version that can record from the top section with some basic effects applied. It's not finished yet. Probably needs the effects from CHAOS. The ERASE buttons sometime fail to erase everything properly and some glitches can be noticed if erase is pressed only once. You have to press ERASE multiple times to get rid of the remaining glitches.
(3.16 MiB) Downloaded 1095 times
Boss BR 80 v0.04.fsm
(3.07 MiB) Downloaded 1091 times
newdsp
Postby MariaSax » Fri Feb 12, 2021 11:09 pm
Not very regulatory but you can use the two other pins of your DIN5 Out and make a short Y cable Male to dual Female. This will not be a problem to connect a single and regular MIDI cable too.Edited September 14, 2018 by Antichambre
MariaSax
Postby newdsp » Sat Feb 13, 2021 5:37 am
One male with two females ? Is that a your every day traditional marriage ? Maria ? Sax ?
newdsp
Previous
