How to fix DSERR_GENERIC and Direct Sound error ?
Postby Camil » Thu Apr 22, 2021 8:00 am
I've had these errors for a few days and don't know how to fix them. I'm using windows 10.
SmartSelect_20210422-083145_Samsung Internet.jpg (32.82 KiB) Viewed 12584 times
Camil
Re: How to fix DSERR_GENERIC and Direct Sound error ?
Postby juha_tp » Thu Apr 22, 2021 10:46 am
Not much information there so here's a generic answer:
Normally this type message means that selected device is locked by (software which uses) ASIO, (WDM/KS) or WASAPI Exclusive Mode driver for audio I/O. Locked device can't be shared with other software (though, there has been some audio interfaces which supports sharing even with ASIO).
juha_tp
Postby Camil » Thu Apr 22, 2021 11:59 am
So how I can check what software blocking Flowstone because my drivers are up to date.
Camil
Postby adamszabo » Fri Apr 23, 2021 5:57 am
It means that FlowStone wants to use your microphone but windows 10 doesnt allow it. In the windows 10 settings enable the apps to use your microphone, and perhaps it will work
adamszabo
Postby Camil » Fri Apr 23, 2021 7:27 am
adamszabo wrote:It means that FlowStone wants to use your microphone but windows 10 doesnt allow it. In the windows 10 settings enable the apps to use your microphone, and perhaps it will work
Thank you very much I had microphone access disabled in the microphone options. I turned it on and the error disappears.
Camil
