Ruby Knob fully customisable
Postby Nubeat7 » Fri Nov 16, 2012 11:12 pm
here is a fully customisable rubyknob.
latest version:
ruby_knob_3_001.fsm
(3.25 KiB) Downloaded 1147 times
Re: Ruby Knob fully customisable
Postby TheAudiophileDutchman » Sat Nov 17, 2012 12:43 am
Great stuff, very smooth :!:
T A D - since 2005
Postby philton » Sat Nov 17, 2012 1:52 am
thx for sharing NuBeat, maybe i understand that Ruby stuff a little bit more when i have a look at your work and how
you made this knob...
philton
Postby Nubeat7 » Sat Nov 17, 2012 11:07 am
philton wrote:thx for sharing NuBeat, maybe i understand that Ruby stuff a little bit more when i have a look at your work and how
basically i tried the things which you can find in the FS userguide, all the grafic stuff is written down there with examples...
Postby unkargherth » Fri Nov 23, 2012 12:22 pm
A ittle update. Made it still more configurable ( Sky is the limit ! )
Changelog inside
rubyknob-v1.1.fsm
(6.62 KiB) Downloaded 1781 times
Be a pointer my friend
unkargherth
Postby trogluddite » Fri Nov 23, 2012 12:49 pm
Great work, guys - this is just what FS3 needs now, a big selection of cool user modules so that folks get a good choice of different 'looks' etc., and stuff to learn from.
And I always preferred the knobs with a sweep arc - I find them so much easier to read at a distance.
Postby Nubeat7 » Fri Nov 23, 2012 11:52 pm
unkargherth wrote:A ittle update. Made it still more configurable ( Sky is the limit ! )
Changelog inside
rubyknob-v1.1.fsm
great update unkargherth, its so much cleaner inside now, also the properties are much better readable with more things to do, thanks for this!
Postby matti » Wed Dec 05, 2012 8:17 pm
How to hide and hold the mouse pointer when turning the knob?
matti
Postby unkargherth » Thu Dec 06, 2012 2:01 am
I understand about hide.. but can you explain in detail what is the "hide and hold" behaviour ?
unkargherth
Postby trogluddite » Thu Dec 06, 2012 9:49 am
Hold is where, when the cursor 'unhides' it is still in the same place where clicked - so changing the control does not move the pointer position, and it is easy to find when you let go of the button.
