toolbox has vanished
Postby NEURO » Fri Oct 29, 2010 3:48 am
the Toolbox has vanished and we cant locate it - even when re starting and re installing. We have tried going to "view" and ticking the toolbox . Must be doing something silly ! Has anyone seen this and how can it be solved ? Problem has only been noticed since upgrading to the latest version - if thats a clue or not ?
NEURO
Re: toolbox has vanished
Postby admin » Fri Oct 29, 2010 11:06 am
It could be that it's been reduced to minimum size.
If this is the case then on the far left-hand side of the application window you should see a vertical separator bar (it's about 6-8 pixels wide). Hover the mouse over this and the cursor should change to the horizontal move cursor (a symbol with two vertical bars in the middle and horizontal arrows on either side). Click, hold and drag to the right to expand the toolbox.
admin
Site Admin
Postby NEURO » Fri Oct 29, 2010 11:28 am
Hello . Yes , thats the 1st thing we tried - no separator comes up , no matter what we try ?? note : This works ok on the horizontal Navigator - when this is minimized .... we just cant find the separator for the toolbox
NEURO
Postby NEURO » Fri Oct 29, 2010 11:32 am
hello . we have now found it .. by restarting , unticking the toolbox in view ( which is counter intuitive ) - then hovering the mouse , the parrallel bars pop up ! :-)
NEURO
