[Ruby] Circular Mouse Checks
Nowadays GUIs have more and more circular objects, be it knobs or buttons. If you have more than one object in your view and want to detect mouse clicks on them, you have to create a method for it.
You can get away with a rectangular check, which is setting up the boundaries of a virtual rectangle around the object and then testing if the mouse position is inside that virtual rectangle.
But you can also check circular. If you draw a circle it has a center point and a radius. The trick is to test if the mouse position is inside the radius.
The schematic will show you how to do a circular check and why it is an advantage when dealing with circular objects.
check_circular.fsm- (1.04 KiB) Downloaded 1412 times
Re: [Ruby] Circular Mouse Checks
Hi T,
Man , that works really well. Cool.
thats very useful, if you would like to play this with any shape you like, there exists a comfortable methode,
the isVisible methode for graphicpaths (userguide p.162)
with this methode you can check if a point is inside a graphicpath, here is a small example based on the one you posted
greez
greez
check_shape.fsm- (707 Bytes) Downloaded 1456 times
Nubeat7 - Posts: 1347
Yes, I know about this method, and it is nice to have. The thing is, polygon checks are much more cpu-intensive. If this is not a concern, then, this goes to everyone reading here, make use of it. If it is a concern, rectangular and circular checks are cheaper on cpu.
@RJHollins, thank you
Good stuff Guys.
Always appreciate the 'education' too !
tulamide wrote:Yes, I know about this method, and it is nice to have. The thing is, polygon checks are much more cpu-intensive. If this is not a concern, then, this goes to everyone reading here, make use of it. If it is a concern, rectangular and circular checks are cheaper on cpu.
thanks for this info, good to know!
Perfect 4 my Endless knob with it's center button...
Keep on doing!
cheers,
Walter
Keep on doing!
cheers,
Walter
Walter Sommerfeld wrote:Perfect 4 my Endless knob with it's center button...
Keep on doing!
cheers,
Walter
Hmmm
that would be so useful.
RJHollins wrote:..control dual concentric rings ??..
for this you can use the widen methode on an arc path when you are using a pen to draw a path and you will need only the area from the pen line...
here is a very basic schematic to do this, but also tulamides methode would work, its without any eventhandling or presetmanagement, but this shouldn't be to hard..
double_knob.fsm- (1.04 KiB) Downloaded 1398 times
