Disable a GUI dynamically
I want the user to select number of instances of a GUI-containing object.
A GUI object can be set to Visible or Invisible. How do you do the same thing dynamically, i.e. per user action?
- chjan
Re: Disable a GUI dynamically
Not sure it's the best method but here is one.
Maybe it's better to modify all control with a boolean input and use a selector and a redraw inside them.
But this way the controls could be not modified but just placed in a module.
(Don't know if there's some drawback like loosing time to redraw on base of a ghost v input ??
Edit: Finally i think that the method is ok.
This version is more similar to what is done when modifying one control.
(just connecting nothing to the v selector for the first input us another module)
Control Visibility3.fsm- Edit: visible when inside another module
- (74.07 KiB) Downloaded 294 times
- Tepeix
That works nice.
Thanks !
Thanks !
Perfect! I tried something very similar yesterday but did not work. I suspect I forgot the redraw feature. This variant could easily be part of the standard module as I see it. Very handy.
Thanks.
Thanks.
- chjan
