Elektron Digitone
Re: Elektron Digitone
Updated schem (now v1.003) in previous post - some bonehead errors in the Mod section knobs connections (only one in ea group was connected, and they weren't properly bipolar).
Hey, thanks for the update- but there were some mods I'd made to the .fsm and wanted to check if I'd missed your errors as well, but the zip only contains the .dll, no schematic
Duckett - Posts: 132
Oops, sorry - corrected now.
Nice. It's going to take me a while to look at all these files. Here is my contribution to the cross-fade idea. An inverted pan controlled a Ruby Tempo Synced LFO that can be used to do rhythmic cross fade between 2 sources. Or you can switch it to manual mode. You can change the x-fade pattern by using a different sequence in the script.
Ruby Crossfader 002.fsm- Made with FS 309.
- (56.73 KiB) Downloaded 775 times
- DSPRU1
I added an automatic random slide to the Harmonics in FlowTone but it still needs more testing and modifications. It's almost like an automatic random Wah Wah pedal without having to touch any sliders. I tried to keep slides pretty slow.
FlowTone v1.004.fsm- Use FS 309.
- (1.3 MiB) Downloaded 804 times
- DSPRU1
