Bitwise strangeness
• Page 2 of 3 • 1, 2, 3
Re: Bitwise strangeness
If you can avoid it, do it. It's basically the slowest math operator... Only some functions (eg. log10, exp, pow) are slower.
MyCo - Posts: 718
MyCo wrote:If you can avoid it, do it. It's basically the slowest math operator... Only some functions (eg. log10, exp, pow) are slower.
I'm only using it to "flooring" a value right now:
pos = index-(index%1);
Will the new compiler have this function? If I don't remember bad, the new int() will do it:
pos = int(index);
right?
- Nowhk
for old versions you can use
for truncation, it works as long as x >=0
in the 3.0.9b1 you can use "int" as it works there and is also a lot faster
y = rndint(x-0.49999991);
MyCo - Posts: 718
MyCo wrote:for old versions you can use
I see (I always think 0.5 was the correct scaling). But why:
rndint(0-0.49999991)
return -0 and not 0? On Some "display" value that's weird.
- Nowhk
Nowhk wrote:I see (I always think 0.5 was the correct scaling)
0.5 would round integer numbers down too, eg. 2 would round down to 1
Nowhk wrote:return -0 and not 0? On Some "display" value that's weird.
Yeah, floating point system has two zeros, so the sign of the input is carried through the operation
MyCo - Posts: 718
MyCo wrote:0.5 would round integer numbers down too, eg. 2 would round down to 1
Uhm...
int(1.5);
rndint(1.5)
(which is 2-0.5) both rounds to 2 (not 1).
MyCo wrote:Yeah, floating point system has two zeros, so the sign of the input is carried through the operation
And what if I want 0 instead of -0 with this technique?
- Nowhk
That's not what I meant, try this to see the difference:
0 == -0 in most cases so just ignore it. When you want to display it at some point using green/ruby you can just compare it like: if x==0 then show 0
streamout o1;
streamout o2;
float x = 1;
o1 = rndint(x - 0.49999991);
o2 = rndint(x - 0.5);
MyCo - Posts: 718
MyCo wrote:That's not what I meant, try this to see the difference:
streamout o1;
streamout o2;
float x = 1;
instead, using x - (x % 1) give to me correct result. Am I wrong somethings other?
- Nowhk
Seems to depend on the CPU:
- output.PNG (26.54 KiB) Viewed 31778 times
MyCo - Posts: 718
MyCo wrote:Seems to depend on the CPU:
So I'll keep (until I'll upgrade to last version, where int() should floor correctly, I hope) x - (x % 1)
- Nowhk
