FlowStone 3.0.9 Beta2
The new 3.0.9 Beta2 is available for download now. Most of the things reported in Beta1 have been fixed, we couldn't fix the bugs that we couldn't reproduce (occacional crashs, although they might be fixed by fixing other bugs, not sure).
Please report bugs in this version her, try to keep it as precise as possible, so we can reproduce it. When you have schematics, reduce them to the minimum.
Thanks!
Maik
[Moderator Note: Please do not use the Betas - they are notoriously unstable! Due to known bugs in other versions, we recommend using v3.0.6 (in particular if you use Ruby, which will leak memory in later versions).
FlowStone development is continuing; to include 64-bit support, VST3 export, and many other goodies - but this is currently only at the alpha-testing stage, with no definite release date or licensing terms announced yet. Please don't post here requesting access as an Alpha tester - this is by invitation only, and not in the hands of the forum moderators].
Thanks!
Maik
Reason: Public announcement added re: FS4.
MyCo - Posts: 718
Re: FlowStone 3.0.9 Beta2
Thats great news, MyCo! Do you have a list of the main modifications/fixes? Many thanks!
You can find a complete list of changes on the download-version page:
http://www.dsprobotics.com/versions.html
MyCo - Posts: 718
Hello Gang,
Also if its not to late, connections should be made like in my drawing (sorry, excuse the poor drawing).
Instead of going from one point out to several connections, connections should go from point 1 to 2, from 2 to 3 and so on.
A shift key could be used when making connections from connections and if no shift key is pressed the connection is lifted as usual.
Hope this makes sense (its late and I am tired).
Later then, BobF.....
- BobF
BobF wrote:
Hello Gang,
Hey Bob,
I understand where your idea comes from, but connecting from an input to another input is not very intuitive. Also, it would not represent what actually happens. Flowstone does not trigger from the blue boxes in this example, it only triggers from the green box, and it does so three times. So, the upper graphic shows what really happens, the lower one is easier handled in case of connection links, but contradicts the real thing.
I'm not a fan of that idea. You can see the main problem of it already in the second drawing. You basically chain modules, they aren't in parallel anymore like they are right now. The trigger has to go from the output to an input and then from there to the next input, and from there to the next input... and so on. What also can easily happen is that one output get indirectly connected to the same input multiple times by chains.
MyCo - Posts: 718
MyCo wrote:You can find a complete list of changes on the download-version page:
I think you should specify that new "int" flooring behaviour: it is very important to know. And maybe also write this on Manual (I don't see any int() specification, only rndint()). For me that's one of the most significant change/fix!
Can't wait for the final release: I'm about to finally buy it when it is out; at the moment I don't think would be smart to waste update time for a beta.
- Nowhk
The int functionality hasn't changed in this release, the change was in the first beta... and it's more kind of a bug fix as it didn't do what it should have been doing.
MyCo - Posts: 718
I'm VERY pleased the MIDI sustain pedal stuck note issue has been solved and I also really like the Save As 3.0.8 feature.
Presumably if my new schematic uses new features, like mouse wheel function, then I would be prevented from saving as 3.0.8?
Looking forward to the final release and many thanks.
MyCo wrote:The int functionality hasn't changed in this release, the change was in the first beta
True, but it could be listed as well on the Beta1 list
MyCo wrote:and it's more kind of a bug fix as it didn't do what it should have been doing.
The fact is: what's the aspected behaviour of int? Always floor to below int? Making it different of rndint(), which is round above/below with "round half to even" as tie-breaking rule?
These two informations should be specified in my opinion. Learning rounding in FlowStone has make me very crazy
- Nowhk
Users browsing this forum: No registered users and 46 guests
