Copy/Paste Utility - VST
Postby RJHollins » Fri Jul 29, 2022 5:27 pm
Hi Guys,
I have need for a Copy/Paste type of utility, and first wanted to check with the GURUS to see if this is even possible with FS.
Scenario:
Working in a DAW, using the Voxengo SPAN spectrum display. We can RT-Clk mouse button and capture a Frequency
marker that temp stores in the Windows c/p feature.
What I'd like to do is make a FS VST that would work like a Notepad that can be pasted on to, to store these snapshots.
Would be ideal if this could be, somewhat, automatic ... in that, each capture would be sent directly into this Utility.
THEN ... from this utility storage 'pad' .... could then be again Copied/stored, to be pasted into an Equalizer that accepts Text/edit entries.
Is this even possible with FS ?
Sure appreciate any insights in regards.
Thanks !
Re: Copy/Paste Utility - VST
Postby RJHollins » Fri Jul 29, 2022 6:32 pm
Just did a fast test, and yes ... SPAN sends to the clipboard ..
and it can be pasted into FS 'TEXT' primitive, and so far, one of my EDIT modules.
so there is possibility.
Thinking ahead.
Say I can get several C/P entries.
I would then want to SORT them Low to High [to better organize].
Don't have a total number of C/P's that I'd want/need ... so leaving that for later.
With the simple test working .... now to think this through more.
Postby Spogg » Sat Jul 30, 2022 7:59 am
Interesting idea RJ.
The closest I’ve come to anything like this is when I make presets. I compose in Word (for the spell checking) then copy-paste into the text field in my preset manager.
My gut tells me that Ruby will need to be involved for converting a data set into text and parsing the pasted text back into a useable format for the use case. I suspect the solution will be specific to the dataset, rather than generalised. I think it might be possible but not by me. Looking forward to seeing where this goes…
Postby HughBanton » Tue Sep 06, 2022 5:59 pm
Sorry to arrive a bit late to this, but only yesterday I clicked on copy/paste in my own project (I hardly ever use its copy/paste facility :-( ) and that in turn made me recall when I originally requested help about this very subject. It's been a hidden feature in my thing ever since. (So hidden I'd almost forgotten it was there :lol: )
viewtopic.php?f=2&t=10582&hilit=paste#p39180
Not the same as you are after, but it illustrates how to use a global variable in Ruby to pass things around. Works well.
However note Tulamide's wise warning about using global variables such as this ... :!: :!:
HB
HughBanton
Postby RJHollins » Tue Sep 06, 2022 6:21 pm
HughBanton wrote:Sorry to arrive a bit late to this, but only yesterday I clicked on copy/paste in my own project (I hardly ever use its copy/paste facility :-( ) and that in turn made me recall when I originally requested help about this very subject. It's been a hidden feature in my thing ever since. (So hidden I'd almost forgotten it was there :lol: )
HB
Wow HB !
Would you know I tried to first Search the FS forums for something like this. Thanks so much for finding and posting.
Had a chance to read through most of that and additional links. Good stuff all around.
Again Thanks ! Hope all is well for You. 8-)
Users browsing this forum: Google [Bot] and 45 guests
